"In wine there is wisdom, in beer there is strength, in water there is bacteria."
818 (Chassis #34) Delivered 9/25/2013, First start 3/2/2014, First drive 4/5/2014, Registered 8/28/2015, First Dyno 3/18/2016, First SCCA event 4/3/2016, First car show HIN Honolulu 4/23/2016
I jumped right in and shortened the tailpiece to fit;
I gave more detailed info in the general, engine/transmission thread.
I still need the measurement from the top of the frame to the center of the axle output to determine if I need to lower the rear of the trans, if anyone has the time.
Anyone have problems with the FFR axles not having matching splines on the wheel hub end? The axles FFR sent me have 29 splines, my rear hubs have 21. Jay said they have not had this issue before and that basically I'm on my own to resolve.
When I built my jeep I had to take the axles to a driveshaft shop to lengthen the front axle and shorten the rear, so I will take the axles down to them to cut/splice/balance.
Call factory five...there we issues with the axles. Although you might measure the stock axle against the FFR axle. I was surprised how close it actually was. mine were about 1/32 different in length...I bet I could have run the stock axles.
Pete, thanks for answering! Yes, that's what I needed to know. That's about the same as what I have, but when you look at the front of the engine to the frame it looks like the engine is tipped forward.
Looks like all I need to do now is build a rear trans mount. I was all set to pull the engine/trans and modify the frame to drop the rear lower tonight.
Thanks again.
Id measure the rear as well. The engine and trans can pivot close to the axles so a large angular displacement gives little movement near the axle but a lot of movement at the rear.
Zero Decibel Motorsports
Check out my new website!
I was going to measure it yesterday just as I saw you posted pics. Then, I didn't feel bad I hadn't measured. :lol:
I finished modifying the frame, built a rear auto trans mount, and installed the engine/trans for hopefully the last time! (More detailed info in the engine/trans threads under auto);
On Thursday I received the B/O hardware from FFR and also the Subaru parts I ordered for the front suspension. New steering rack boots, tie rod ends, ball joints and cones for the control arms. So I was finally able to get the front assembled!
Now another major mess to clean up! Seems like I spend almost as much time cleaning and putting away tools as I do actually getting some building done.
Now that I have the hardware and the auto trans installed I can get little projects done on weeknights. Hopefully start moving a little faster.
So Wayne showed us that the 6 cylinder will fit.......do you think it will fit with this tranny set up? It would be my preference ........thanks Steven
FFR Daytona Type 65 Coupe
67 427 Cobra
57' Belair
34 5 window coupe Ford
2003 Mustang GT
99' ZX9
85 Goldwing
Are we having fun yet? I keep asking myself as I wire brush/clean/paint nuts, bolts, and greasy/rusty brackets/calipers/rotors/etc.
I painted the front firewall with spray on bedliner, started fitting the master cylinder, and installed the steering column. For the steering rack I used my new tubing bender and made a loop in one of the power steering lines I took off to patch back;
Since I'm using an auto I had concerns that fitting the brake pedal would present another challenge. It did, but very minimal. The bracket assembly bolted right up, drill a second hole in the pedal shaft for the pushrod connection, and shorten the pushrod by about a half inch;
So between using an auto and that my donor is mostly a 2000 imprezza outback, with the rear suspension being from a 1998 forester (the outback didn't have disk brakes), I have few more challenges to overcome than if I had been able to find an "approved" donor. So this weekend it was time to conquer the brakes. Still waiting on another set of axles with hopefully the right spline count in the CV joint at the wheel end to fit the FFR supplied axles. It appears that the calipers from both donors are ok so I cleaned them up and painted with caliper paint. Took the disks to O'Reilly to get turned and pick up new pads. The fronts had enough meat left to turn, the rears too warped. Luckily they had the rear rotors and both sets of pads on hand. While I was at it I painted the center of the rotors black;
I guess when a few more get done with their builds we can compare notes on what is really required for brakes. So my setup is completely stock, including off the shelf pads for future reference. No power brakes. If I was building for track use it would be a no brainer, go for the Wilwood upgrade. But with the 818 weighing about half of the donor, I can't imagine that stock brakes will not give above average stopping power.
So a little note to those building behind me,
Fit all your parts and install the bolts, washers, spacers, nuts, etc as shown, but do not tighten! I typically do this anyway, I can't tell you how many times I have needed to take something apart that you think your done with, to get another part in. It has saved me a lot of time, especially since parts are on back order or waiting on other parts. I was reminded of this tonight when I went to install the front sway bar. You have to remove a top shock mount bolt to get it in place.
see photo 1 above:
your rear lower LCA bushings are mounted incorrectly, the side with the little "wiggle" is supposed to be down, the flat side on the top, swap and flip
there is a small funky shaped block off plate to go between the firewall and the master cylinder
Dan
Looks great. Very sharp looking.
Dan thanks for taking the time to review my pics and comment! There has been many conflicting posts/information about the installation of the LCA's that I temporarily bolted them in place until I felt the issue was finalized. So today I picked up some nuts and bolts, flipped them around, and bottled them in. I also painted the cover plate for the master cylinder with bed liner paint and installed. The plate did require some cutting to clear the top right master cylinder bracket bolt, FYI.
I installed the front sway bar also. My wheels are on island now, hopefully delivery tomorrow. If my axle parts arrive this week I plan on having the baby stand on its own feet this weekend!!
A,
You're doing an outstanding job. I'm really looking forward to the karting of your auto-818. Keep up the great work.
R/s
Vidal
CURRENT STATUS: Interior Rework and Bodywork.
GenII GTM #331. Delivered (23/9/10)
BUILD LOG AND WEBSITE:
http://gtmbuild.weebly.com/ .
You are really flying along! The build is looking great, and you must be pleased.
So, how has it been working in the space you have? It doesn't appear to be slowing you down any!
I have enjoyed watching your progress. Looking forward to the go kart!!
Dan
Thanks for the positive comments! Actually the space is working out perfectly. Parts have been coming in as existing parts have been getting installed. Trash has to be hauled out often as all the cardboard and packing fills up a lot a available space. But maybe good, makes me clean up more often. I am having a great time building the 818 so far. Even with a few conflicts with information and Subaru parts variations, nothing has been frustrating. The frame and components have been laid out pretty well and component installation makes sense. My best tool has been my little angle grinder. Cut a little here shave a little there, etc.
Thanks for the compliment. My little plan for myself is to go cart by end of November and spend December on body and interior. I have been spending most Saturday's, part of Sunday and 2-3 nights a week for a couple hours building. Untold hours researching and buying parts.
I'm not sure if my method is correct or what, but I tend to stop work on an item when I don't think I have clear direction/understanding, and move on to something else. With the thought that after I get partway through that part installation I can get back online and research and having actually starting the install helps me understand better what Im reading in the everyone's posts. Then Im not wasting time trying to figure it out by myself. The LCA issue is a prime example, and one of the reasons I only assemble now and torque later. Thanks for your time in replying and putting this issue to bed!
My wheels finally arrived, ordered on 10/4, delivered 10/23, shipped from California. I call shipping cost and time delay the Hawaii "Tax". Nothing for free!
The wheels are XXR, 535's in Chromium Black, 17x7 front, 18x8.75 rear, all +35.
I had in my mind, after reading all the posts on wheel size, that I needed to push the boundary of size. My opinion is that these wheels are pretty big just looking at them hanging on the lugs. Obviously my body is not on, and I don't have tires yet, to completely verify fitment. But I can say they I only have about a half inch clearance on the backsides. I am really excited about how they look in person. I was hoping for a little more "deep dish" look, but its there a little on the rears. No offense to Wayne's XXR wheels, but the double bolt pattern bugs me, I'm so happy I found these with just the single 5x100 pattern.
Awesome fit, there's hope yet for my 9.5 rears. Your box says 9.5... were they really 9.5s that measured at 8.75?
Tonight I plan on assembling the suspension and getting some good measurements.
Love the wheels! I think they will look very sharp.
You are really cruising right along, and things are looking great. Are you going to stay with the white, or are you going to lay down some paint? After seeing Wayne's, I really like the idea of some color on top, although I don't have the creativity he has as far as that cool design!
Thanks for keeping us up to date. I am enjoying following along! Did I catch a picture without the hula girl? Or, did I miss her?
Keep on trucking along!
Looks great! I'm thinking about the XXR 530's in Chromium Black, so I'm anxious to see how your fitment turns out when the body panels are on.
The wheels I have on my Z (Nismo LMGT4, made by Rays) are like that and I've kinda grown to like the 10 hole look...
I hate to point out an error online, but this is important. The hula girl is missing in your last photo - the right rear wheel. Did she quit and walk out on you?
Whew. Good catch, Les. I've had them walk on me and didn't want that to happen here.
R33... sweet!
Yeah, I got a deal on my wheels; forged monoblocks are super light, the XXR's that Aloha got and I'm considering cast; any chance of putting them on a scale?
Good to know about the center caps, but I'll be selling my Z in the near future.but I'll be getting my 818 tomorrow or Saturday
According to this website: http://www.nlmotoring.com/XXR-530-Wheels-s/1673.htm, the XXR 530 17x7 weighs ~19.5 lbs, and the 18x8.75 weighs ~21.2 lbs.
Sweet wheels!!!
67 427 Cobra
57' Belair
2003 Mustang GT
99' ZX9
85 Goldwing
Thanks for commenting.
I will not leave mine white. Although some of my friends like white. I keep changing my mind on color, so it will probably be like roulette, when the time comes for color it be what Im thinking at the time. I plan on a black interior with lots of red. I have already purchased a black steering wheel with red stitching, powder coated all the exterior body trim pieces satin black, and my wheels are blackish looking, so my exterior colors will have to match. My current inspiration;
Having a time trying to find tires here, I even went on some mainland sites but it seems like most of my first choices are on back order, long lead time, or expensive shipping. I'm anxious to get to a rolling chassis so I might just pick up some cheap tires to get through the build. Been looking at Bridgestone RE-11's, Advan AD-01's, Toyo R1R's, and Hankook R-S3's. I should have started looking earlier.
Thanks to all for the reply's about the Hula Girl!! Sometimes she gets a little shy at all the picture taking and she try's to get out of the limelight![]()
Perhaps I can help. These are the tires I was planning on:
http://www.onlinetires.com/products/...acing+83w.html
http://www.onlinetires.com/products/...g+90w+bsw.html
According to all the information I could find, they should fit the wheels you have fine. Price is right too.
There was a thread some time back about tires and from what I recall these were said to perform very well (despite being not very well known).
For what it's worth...
