Results 1 to 8 of 8
Thread: Value of power steering
    Senior Member rcotner's Avatar
    Wilsonville, OR
    I am new to this car bulding thing as will probably be obvious by my questions but...
    I chose to NOT get the power steering option. My thinking was that a light car will be fine without it. I would really appreciate it if some one with wisdom would comment on this. Does anyone without PS wish they had it? Can it be retrofitted post initial build if desired?
    Ray
    IMO the electric P/S is a no brainer. Yes you can drive the car without it. But it makes the driving so much better. I would never build one without it unless it was a pure racecar. You could retrofit but it makes better sense to do it from the getgo IMO.
    Senior Member Arm7419's Avatar
    Sedona Az
    Ray
    I second the above. You won't regret it, believe me.
    chuck
    Chuck
    Mk1, MK3, Hotrod, Gen 3 Daytona Coupe, RF GT40
    Hang Up and Drive
    Senior Member Quiny's Avatar
    Massachusetts
    Do you know of a good electric P/S setup for the 818?
    Quote Originally Posted by Quiny View Post
    I built a 33 with P/S and am building a 818 now. The 818 is a differant animal. I don't see the need for P/S due to the light weight and smaller tires IMO. You would have to modify the electra steer to the 818 kit yourself. No one is offering one as yet. It is doable but not worth the cost or bother to me.
    Senior Member Jay Mann's Avatar
    Aug 2011
    Car is in Edmonton
    I thought the same as you, (I drove armstrong steering cars for many years) until I tried to manuever those 245/40/17 tires. The issue us not the weight of the car, but the force required to turn those tires. I just installed the power steering last week, after almost 2000 miles without it. It is worth it, I bought the unit directly from Powersource ( Summit Racing) at a very good price. I installed a switch so I can turn off the assist when I want to.
    www.33coyote.com
    Built with the help of my dad and sons
    coyote/TKO 600, Wilwood Brakes,Boyds tank, QA1 shocks
    Speedhut Gages, rag top, bike fenders, power steering
    "Never let physics or common sense get in the way of a good idea"
    Senior Member narkosys's Avatar
    There is also a very good kit from Fast Freddie's.
    P
    Wilsonville, OR
    All excellent advice! Thanks! It looks like I am in the market for a PS unit.
