Page 18 of 26 FirstFirst ... 81617181920 ... LastLast
Results 681 to 720 of 1011
Thread: Wayne Presley/VeryCoolParts Build Thread H6 power
  1. #681
    Jul 2012
    Atlanta GA
    Put the car on the scales this morning, 1974 lbs with 3 gallons of gas. 40% front, 60% rear and 50/50 right/left with 50/50 cross weights.
    That is very impressive! A turbo flat 6 under 2,000 lbs Wet Weight.
  2. #682
    Aug 2012
    Long Island
    Craigslist be like, freshly machined block!
  3. #683
    anderson
    power steering rack conversion to non power
    hi Wayne
    i watched your video on converting the power rack off a 2002 subaru i was wondering what you did with the holes left from the hoses you removed?
    kerry sylvester
    Since my kit should be ready this week to ship I'll let everyone in on the build.
    motor EJ20
    Ported head - Mid level porting job, 5 angle valve job
    JE 9.5 CR pistons
    King XPG bearings
    ARP head studs
    Moroso oil pick up
    750cc Deatchwerks injectors
    255lph Walbro pump
    Garret GT2560 BB turbo
    Enkei Kojin Wheels 17x8 18x9.5
    Toyo R1R or R888 tires
    Hawk DTC 30 pads
    Stand alone car harness
    Electromotive TEC-S, special built for VCP to work with the Subaru coil on plug. Built in boost control.
    Sparco D ring steering wheel with Sparco adapter
  4. #684
    Freeport, ME
    loop the hoses... you can reduce the friction by removing the piston seal as well. If you remove the seal, you don't need to loop the lines, you can plug them...
    Dan
  5. #685
    anderson
    thanks alot
    kerry
  6. #686
    anderson
    where is the piston seal? is there one on both ends to remove?
  7. #687
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    Quote Originally Posted by indiana818 View Post
    The piston seal is in the middle of the rack.
  8. #688
    Freeport, ME
    there is a de-powering the rack thread somewhere on this forum, pre-05 rack is one style, 05-07 is another
    remove the end cap, push out the rack
    remove the seal, you don't need to remove the whole piston
    grease
    reassemble
    plug the two line ports
    note: the fluid was not used for lubrication, the rack slides vs bushings on each end
    Dan
  9. #689
    QC, Canada
    For the weight, 897kgs isch.
    Tracked May 27/July 26, 2017
    Build Completed Winter 2021
  10. #690
    Administrator
    Enterprise Alabama
    Interior is done
  11. #691
    Huntsville, Al
    Very Nice!!! I really really like it...can't wait to see it again next week at SEMA
  12. #692
    Jan 2012
    Very nice Wayne!!! Do you plan on getting the new door panels in the future or keep it the way it is?
  13. #693
    Junior Member Scott J's Avatar
    Plymouth, MA
    3 gorgeous 818s' going to SEMA! I can't even decide which one I like the best. FFR, Wayne and Eric have all set the bar so high for us "budget" builders. Sales of this kit are bound to go through the roof after SEMA. Outstanding job to all of the early builders. Keep the pictures coming.
  14. #694
    Administrator
    Enterprise Alabama
    Quote Originally Posted by 07FIREBLADE View Post
    Those are the new panels, the uphostery guy has some bad glue and he had to improvise. After SEMA the panels are going to be recovered, they looked great but the wouldn't stick on the fiberglass pockets. So he whipped out some panels that needed nearly no glue.
  15. #695
    Nov 2012
    Huntsville, Al
    Nice job on the interior- love the dash and the steering column cover.
    Could you answer a couple of questions?
    What are the bars in front of the seat? They look like part of the frame?
    Why the exposed aluminum panels in the lower door frame and upper door frame where the door latches? Just not quite completed for the evening or is it a design issue?
    Maybe I'm not following what you mean on the door panels- these are the new panels, but not quite as they come from the factory?
    Great color, great job on documenting the build. Appreciate the input!
  16. #696
    Senior Member THE ITALIAN's Avatar
    Coastal So Cal
    What did you use for a rear view ? Can you see well at that position ??
  17. #697
    Jan 2012
    Got ya Wayne. They looked different when you compare them to the finished appearance of the white 818S in the yahoo video that's why I made the comment. Cool can't wait to see the way it looks after SEMA. Very impressive build
  18. #698
    Administrator
    Enterprise Alabama
    Quote Originally Posted by ktm View Post
    What are the bars in front of the seat? They look like part of the frame? They are part of the frame.
    Why the exposed aluminum panels in the lower door frame and upper door frame where the door latches? Just not quite completed for the evening or is it a design issue? There is no exposed aluminum, reflection off the powdercoat makes it look that way.
    Maybe I'm not following what you mean on the door panels- these are the new panels, but not quite as they come from the factory? They are factory door panels with pockets and contours. The glue would not hold down the pockets so upholsterer went to plan B.
    Quote Originally Posted by THE ITALIAN View Post
    You reuse the WRX side and rear view mirror and have decent rear views.
  19. #699
    Beverly Hills, FL
    Where are the cup holders? Gotta have a place for a super big gulp (well, everywhere except in NYC!)
    FFR4958. IRS, 408W, Loud and fast!
  20. #700
    Administrator
    Enterprise Alabama
    It's done enough for SEMA
  21. #701
    Edmonton, Alberta
    Amazing job!
  22. #702
    Mechie3's Avatar
    Indianapolis
    Did you add something to the side cutouts? Can't tell if it's a shadow or not. It looks great though! Excellent work!
    Zero Decibel Motorsports
    Check out my new website!
  23. #703
    That is truly something to be proud of.
    Bill Lomenick
    Chotis Bill
  24. #704
    Administrator
    Enterprise Alabama
  25. #705
    Administrator
    Enterprise Alabama
  26. #706
    Mark Dougherty's Avatar
    Hershey PA
    wayne
    awsome job
    great push to get it done
    The traveling Builder
    717-773-5624
  27. #707
    Senior Member AZPete's Avatar
    Thanks, Wayne, for setting the bar so high. Or, as Dave Smith would say, it makes us all reach above our grasp.
  28. #708
    Administrator
    Enterprise Alabama
    I made covers for the latch support bolts last minute, as in started 30 minutes ago...
  29. #709
    QC, Canada
    lollll nice trick Wayne.
  30. #710
    QC, Canada
    Guys, not so long ago, that car was naked and doing donuts in the grass. And look at it now.
  31. #711
    Huntsville, Al
    wicked!!!!!!!!!!!!
  32. #712
    Junior Member 818dennis's Avatar
    Jun 2012
    Wayne I love your VeryCoolParts #704 and FactoryFive 818 #705 Decal. Last night I went through and saved all the picture that you posted 129 of them. So I could relive them with a slide show and it was great!!! I wished I could some how post them here so every body could see them, might sell some more cars. Great job . Maga Awesome!!! Thanks, Dennis Nelson
  33. #713
    Nov 2012
    Huntsville, Al
    Nothing like pushing it to the limit to meet a deadline. Very nice work. Very nice!
  34. #714
    Administrator
    Enterprise Alabama
    I had the car vacuumed and started to fit the FFR stock cover panels and I wanted a little more coverage. Got out the poster paper, cut a template and transfered it to a sheet of aluminum, cut them out on the band saw, bent it in the brake and covered it with matching carpet. 20 minutes on the first and 10 on the second.
  35. #715
    Aug 2012
    Long Island
    Let's see the embroidered floor mats!
  36. #716
    Troy, AL
    The car is beautiful. Any videos of it running yet?
    Mike Shelton
  37. #717
    Administrator
    Enterprise Alabama
    No vids of it running yet
    It's loaded and on the road to SEMA
  38. #718
    Exeter R.I
    My kit came with dome covers like that
  39. #719
    Senior Member gwader's Avatar
    Torrance
    Dang!!!!! Full treatment. On a serious note. Now much fab work in total hours spent? Brackets etc not included in kit. Do you guys report your findings back to FF. So they can add those items to future kits?
  40. #720
    Administrator
    Enterprise Alabama
    I didn't keep track of hours to build the car as I built the GRM car in the middle of it. Tons of feedback went back to FFR and were incorporated into the new kits.
