Page 1 of 4 123 ... LastLast
Results 1 to 40 of 138
Thread: SixStarCars' 818S Build Thread
    Feb 2013
    Westminster, MD
    Cool SixStarCars' 818S Build Thread
    We will be covering the building of FFR 818S #80 for Charles in St. Louis
    Goal:
    To build an 818S from one donor as close to the manual as possible while sticking to our client's budget.
    Donor:
    Our car was purchased through COPart in Denver. Didn't look too bad from the pictures, come to find out....
    Not bad right?
    Actually kind of nice!!!
    Oh snap!! Literally. We knew about this though so no surprises there.
    Timing gears sitting on top of the engine never a good sign.
    Not even hit that hard in the front, there was some protrusion into the engine bay that hit the side, very odd. But strange things happen in accidents. A word of caution. This engine will need several parts and a bit of work before it can be tested out, as always with crashed cars BUYER BEWARE!!!
    Right rear is tossed
    Won't be using that mount, or dynoing the car, bummer.
    Subframe wasted
    Banana!
    Aug 2012
    Long Island
    Craigslist be like, "needs alignment"
    Jan 2012
    Craigslist be like, "that will buff right out"
    Feb 2013
    Westminster, MD
    "Custom rear end"
    Senior Member Xusia's Avatar
    Eugene, OR, USA
    Thanks, guys. Those posts just made my day!
    Senior Member Quiny's Avatar
    Massachusetts
    So what did you see behind the dash to know that they flashed the ECU with a Cobb? I have Cobb tuning stickers all over my donor so I assume the same. I haven't looked into it yet but I will want to return it to stock, I hope it can be done with Opensource. I may tune it from there but I always like to start from stock.
    Aug 2012
    Long Island
    The cables near the green test mode connectors were probably pulled down out of the bunch to where they are easy to access, (you need to connect an initialization coupler) indicating that the car had been fiddled with.
    Feb 2013
    Westminster, MD
    ^ Yep. Can't say for sure but knowing what I know it's clear it's been fiddled with.
    Jan 2013
    Unless I missed it, who are you using for shipping? That $857 to Greeley is a great price.
    Feb 2013
    Westminster, MD
    Quote Originally Posted by DurangoRon View Post
    We went through uship.com, it's a bidding site for LTL. I'll get the name of the actual shipper as soon as I can for everyone. That's each car plus crates. So $3114 total. A few hundred off "the other guys" price and they SHOULDN'T get damaged which was our main concern.
    Feb 2013
    Westminster, MD
    UPDATE 1: 11/18/13
    Tore into the donor today, looks like we have some bent valves on one of the heads, codes lean toward #4 which is interesting since that wasn't the side that was hit. But I have seen this before, the gears that explode generally end up slamming the valves shut and saving them.
    Major parts out of the way:
    http://i.imgur.com/nyjsiHC.jpg
    Your cam gears should NOT look like this!
    http://i.imgur.com/VKA7o6z.jpg
    Belt on and she runs, but rough. Instant #4 misfire code.
    http://i.imgur.com/wpGXwfX.jpg
    Senior Member BrandonDrums's Avatar
    Triangle area, NC
    Quote Originally Posted by SixStar View Post
    UPDATE 1: 11/18/13
    Attachment 23461
    Attachment 23462
    Attachment 23463
    Ahh pooey, those image links arent working....I wanna see!
    QC, Canada
    Nope, not working.
    Tracked May 27/July 26, 2017
    Build Completed Winter 2021
    Feb 2013
    Westminster, MD
    Not sure why it amended and killed the links, sorry. They're fixed now. I'm only allowed 10 pictures per thread.... even hosted on imgur, seems silly.
    Aug 2012
    Long Island
    Do you guys do any work with Flat Iron?
    Feb 2013
    Westminster, MD
    We have an account there, Preston is the man!! Also we work closely with Dwight and Peter at SCR who build the motors for Flatiron.
    Colorado can be very small when you've been doing the same thing for 18 years!
    Feb 2013
    Westminster, MD
    Looks like both our cars SHOULD be picked up today which means a possible delivery Monday. Stay tuned.
    Feb 2013
    Westminster, MD
    If it's not one thing it's another. The estimated 11/23 completion date came and went. By the time the cars were done it was the holiday and the freight company tried to pick them up Friday but FFR was closed (rightfully so, I was as well). Driver had better things to do yesterday I suppose, tried today and since they didn't call ahead the cars weren't in the crates ready to go.
    Frustrated.
    QC, Canada
    Ha man. Such bad luck.
    Feb 2013
    Westminster, MD
    Got some more goodies for our 818 build - http://i.imgur.com/CS3ajRS.jpg
    Bad news, I won't be flying to PRI tomorrow as I had to have my appendix removed yesterday... good news I will be able to be at the shop Thursday for the delivery of our 818s! How's that for a silver lining?
    Dec 2013
    Hey SixStar...when you get cars and get started on the project would there be any way me and my build partner could stop on by and check out the cars and see how things are going and just chat in general about the build process, donor acquisition, etc?
    Johnstown, CO
    Feb 2013
    Westminster, MD
    Quote Originally Posted by crossbarphoto View Post
    Johnstown, CO
    Yes of course. It'll be slow going for the next two weeks while I recover, but you're welcome to come by anytime and check them out.
    Once I'm done with the chassis mods on both they'll be off to coating, should be gone a week or so. After that they'll live at the shop.
    Dec 2013
    I was thinking about seeing the delivery, but that probably won't be all that exciting. A couple weeks might be best. I'll keep following this thread to see how things are progressing. We put our order in a few weeks ago so we have time, but there is LOTS to do between now and then. Hope you heal quickly.
    Thanks!
    Feb 2013
    Westminster, MD
    Two large wooden boxes and my Cat 40. Pretty boring.
    We'll have a bunch of unpacking photos and maybe a short write up on how it all went.
    Aug 2012
    Long Island
    Why did you decide to get the crate? Short on firewood?
    I thought Aloha had said that even with the crate a few parts were scuffed/chipped. Do you think it was worth 700 each?
    Feb 2013
    Westminster, MD
    Without getting into specifics, another build was delayed after Stewart damaged some parts and caused some other hardships for the customer. Until he's willing to come forward about his experience that's all I will say.
    Armed with that information we chose to use anyone BUT Stewart and the $1400 was our way of adding a little extra safety to our delicate and expensive cargo. I'll know tomorrow if there is any damage.
    Feb 2013
    Westminster, MD
    Todd got into the donor a bit more this past weekend
    Seats and some interior stuff:
    http://i.imgur.com/Acw89dH.jpg
    Cars get very large when you take them apart:
    http://i.imgur.com/YLMat4P.jpg
    Barf:
    http://i.imgur.com/uH2GuhY.jpg
    More barf, glad the electrical engineer is in charge of our wiring!
    http://i.imgur.com/B8ys6cR.jpg
    Cars should be here by 3pm today. Lots more pictures to come. Also check out our Facebook page @ facebook.com/sixstarcars818
    Feb 2013
    Westminster, MD
    Well the cars FINALLY showed up tonight. Nothing too exciting, just uncrating the R and disassembly. Inventory tomorrow and uncrating the S.
    High res album - 27 pictures - http://imgur.com/a/GAFy9#0
    Orange, CA, USA
    Did you ever get a chance to get the name of the shipping company?
    Feb 2013
    Westminster, MD
    It left FFR on Cap Cod (or something similar) it's at the shop. I'll be there later today.
    I can tell you this, the last leg was UPS and what a bunch of useless morons. They showed up Wednesday, I wasn't there since I had only been out of the hospital about 30 hours, one phone call and I could have had someone there in 45 minutes. Instead they chose to turn around and go back to Denver and mark it "refused". They didn't even try Thursday, I was there all day waiting. Then yesterday morning they said it would be Monday, Todd called and chewed them out and they 'found' a truck to bring them up. I'm not sure what they loaded them with but they pushed both crates all the way forward and had zero dollies on the truck. We ended up having to drill holes in the crate and mounting a tow hook, from our NASA TT car, to the actual crate and pulling them to the back with the Cat so that I could get under them. How they thought we'd get them off I'll never know.
    The 818R was in great shape, minimal scuffs on the panels, the hood took a little damage being upside down in the cockpit of the car with a few more parts piled on top of it but nothing that won't be covered by the livery wrap. In all I was VERY impressed with the packing job. Wait till you see what we have planned for the crate, can't let all that well engineered lumber go to waste!
    Feb 2013
    Westminster, MD
    Made it about 90% through inventory of the 818R today. Missing a few key items, won't be able to make it a roller as soon as I wanted, oh well.
    Back to work on the S tomorrow. Our photographer will be there to take a bunch of unpacking pictures for the site. Is there anything anyone is curious about receiving your 818 that hasn't been covered yet?
    Feb 2013
    Westminster, MD
    S is unpacked and inventoried. Got started on the R, first part, doesn't fit. This better not be a sign of things to come
    Had to ream the holes for the UCAs to get the bolts to go in. Still looking for the spacers (.821) for "track only", got tired, called it. Three nights in a row of 818 is too much for me right now.
    Should have the R rolling tomorrow then I can get it off the lift, get the S on the lift and stripped down to head to paint. No frame modifications on the S we decided.
    Feb 2013
    Westminster, MD
    Holy delayed update Batman!!!!
    We're back hard at work on the #80 818S. Slight changes to the donor used, we went with a 2.5RS for the suspension and steering column as well as some other bits. Ran into a slight issue with the 2.5RS clutch master, it will not work on the 818.
    Here you can see that with the RS resi the cap comes into direct contact with the frame before you ever bolt it on
    You can see the differance between the WRX and RS resi
    Easy fix, just use a WRX resi with your RS donor and move forward!
    Here are some more pictures of the build. On to mounting the seats, doors, and hanging the body. Ignore the mismatched rear LCAs - they're temporary!
    http://imgur.com/a/WYzNk#0
    #80 is a roller! And despite our difficulties in figuring out the seat brackets you can sit in the car and make vroom vroom noises now too!!
    My take on the seat bracket instructions:
    Feb 2013
    Westminster, MD
    3/11 update - 1/4s are mounted and aligned. Doors are being hung and mirrors mounted. Hoping to have everything south of the front firewall mounted up by the end of the say.
    http://imgur.com/a/6WgPc#0
    Feb 2013
    Westminster, MD
    Nate and I have been HARD at work getting #80 together. We focused on getting the body mounted and squared up, doors and mirrors hung and functional and I'm pleased to announce we have what LOOKS like a Factory Five 818S finally!!!
    Aug 2012
    Long Island
    very
    nice.
    Nov 2012
    Medina, OH
    It's so easy to enjoy those steps of the build that result in a huge visual impact.
    Rich
    Senior Member Brando's Avatar
    Irvine, Ca
    That is hilarious
    It still would be an improvement over R specific directions
    Feb 2013
    Westminster, MD
    MOAR pictures - now with more poke.
    Working on getting the headlights and tail lights installed to complete the look of the car.
    Feb 2013
    Westminster, MD
    Quote Originally Posted by Brando View Post
    That is hilarious
    We've been building off the 1G manual. I just got the 1F supplement from a fellow builder and it's clearer but we only received 3 seat brackets so we still can't put the passenger seat in.
    The R.... well lets just say I'm glad I have an experience hot rod builder helping me. Body mounting on that car is next. Everything needs to be removeable so we're going to have a few extra boxes of rivets and I have a rather large order of Dzus and Moroso fasteners coming from Summit.
