Page 20 of 27 FirstFirst ... 101819202122 ... LastLast
Results 761 to 800 of 1063
Thread: And it begins..."The Flash" Build Thread
  1. #761
    Senior Member FFR-ADV's Avatar
    NH
    I have 265's and they fit fine...
    Hi Erik,
    I might have missed it but could you list the front & rear tire sizes, wheel sizes, offsets, spacers and which Federal tires you are using. You used Wayne's wide tire rear trailing links, but did you make any other special accommodations to make it work?
    Thanks so much for your generous sharing of your very special 818S build with this community!
    Cheers!
  2. #762
    Huntsville, Al
    sure!
    Federal 595 RS-R's
    Rears: 265/35/18
    Front: 235/40/18 (these are too wide and rub the inner wheel well...will have to notch the aluminum or go to a 215/40/18 which they make in the SS-595)
    Enkei Raijin 18's (VCP supplied)
    Fronts: 8.5 5x100 45 offset
    Rears: 9.5 5x100 45 offset with 10mm spacer and 3 inch ARP studs on STOCK control arms. I did space the upper rear trailing arm inboard.... also in order to jack the car up you have to tether the rear suspension since as the suspension droops you gain toe in and at max droop the tires contact the lower trailing arm (Wayne's arms account for this)...I will probably place some travel limiters instead. I won't be jumping the car anyway and it only happens at FULL droop.
  3. #763
    Huntsville, Al
    Started the interior work today...will get the dash top covered this week and hopefully get the window in on Friday...
  4. #764
    Edmonton, Alberta
    The red looks really nice on the dash. Is the centre console between the shifter and dash included in the kit?
  5. #765
    Huntsville, Al
    There is a center console included.. This is not it though.. I am making my own B-)
  6. #766
    NH
    Hi Erik,
    Thanks for all of the Wheel Tire info in one place. Your build is an inspiration. Wow! The interior looks great!
    Thank you for sharing!
  7. #767
    Summerfield, NC
    Looks great.
    Is there a panel that will cover the gap between the top of the dash and the front clip?
  8. #768
    Beverly Hills, FL
    Beautiful job!
    FFR4958. IRS, 408W, Loud and fast!
  9. #769
    Huntsville, Al
    Dan, the front glass has a black surrounding that will block your view of that area
  10. #770
    Ok Erik, cuz you're the only one as of now (oh wait, is Wayne running 265s as well?), I have to ask you something, about your feelings. No no no, I'm not like a girl asking about a guy's feelings, let me rephrase plz.
    You have more experience than I do about that, so could you tell me if you think I am heading in the right direction: I won't use a Subaru engine, I plan on fitting a VW VR6. My problem. According to my guesses, this would shift fwd the weight distribution, cuz the VR6 is transversal (engine+tranny) and a little heavier (about 193kg total with tranny) and not much, if anything, would be sitting behind the axles.
    That being said, I estimate the 818 would behave a little more in an understeer way (EDIT: OVERSTEER! See post #773). To account for that, I thought that instead of the neutral FFR recommended 215front/255rear I would upgrade to 215f/265r.
    That second thing being said, my question to you is: are you happy with your 265/35/18? Would you do it again? Was it fairly easy to fit (assuming wheel wells installed)?
    tnx a lot for your opinion again, Erik!
  11. #771
    Huntsville, Al
    Frank, to your first question....I have no idea.. but if read my previous post I would have run 215/265
    "Front: 235/40/18 (these are too wide and rub the inner wheel well...will have to notch the aluminum or go to a 215/40/18 which they make in the SS-595)
    to your second post..
    other than the fact that they fit in there with the wheel wells installed and they fit nicely under the car....I can't comment much on how much I like them other than they look pretty nice stuffed in there
  12. #772
    So I'm going on 265s, then. But maybe on 9.0" rims, not 9.5 (if ones I want aren't made in 9.5). Tnx a lot Erik!
    Also cuz the tires I look for have a section width of 10.7" (instead of 10.6) and 10.2 of tread width instead of 9.6"). They should be 0.1" narrower.
  13. #773
    I was wrong. Sorry I meant OVERSTEER, not understeer. The result is the same, just not the right choice of word.
  14. #774
    818 Junkie... bstuke's Avatar
    Atlanta, GA
    Happy Birthday Erik!!!!!
    818R For Sale!
    818R Sale Thread
    PADI Master Scuba Diver Trainer, PADI TecRec Gas Blender Instructor, Operations Manager - DNS Diving, Grand Cayman
  15. #775
    What? It's his bday??
    HAPPY AGING, ERIK!!
  16. #776
    Happy birthday GOOD friend!!!!!!!!!
  17. #777
    Huntsville, Al
    Thanks tony
  18. #778
    Tech Support Manager, FFR Tony Zullo's Avatar
    Happy birthday buddy!!!! Car looks great...
  19. #779
    Huntsville, Al
    Thanks Tony... Wayne got me a member only jacket too funny....you want my old one
  20. #780
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
  21. #781
    Huntsville, Al
    thanks buddy!
  22. #782
    Exeter R.I
    Have a good b day man
  23. #783
    Jan 2012
    Have a good b day too.
  24. #784
    Huntsville, Al
    Thanks all...had a good one!
  25. #785
    Huntsville, Al
    Got my console done today
    Tried my hand at wrapping today as well. Placed a carbon fiber inlay in the dash...serves two purposes...1. looks pretty cool. 2. should keep the reflection down..the paint was very bright!
    Covered the dash as well...put it all in there for final fit adjustment...will pull it all back out tomorrow and hook up all the electrical connections for the last time...then on to carpet!
  26. #786
    Senior Member AZPete's Avatar
    Nice work on the dash and I like your console design.
    Erik, have you tested your ABS? If so, can you tell us if it is working, please. One proportioning valve on the fronts and an aftermarket ECM, right?
  27. #787
    Huntsville, Al
    have not run or powered the ABS yet...still tons to do....yes one prop valve to the fronts, but I rewired the ABS so the fronts are paired together on the same circuit...I also plumbed it that way . also custom ECU
  28. #788
    Senior Member Xusia's Avatar
    Eugene, OR, USA
    Hey Eric, some questions if you don't mind:
    1. Which carbon fiber wrap are you using? Do you like it? Is it suitable for exterior body panels as well? I'm looking for something I can use both on body panels, and on the interior.
    2. Where did you get the Factory Five logo on your tach? If you had it printed, do you have a file you can share that I can take to a local printer? If Factory Five has fonts, art, or other available, how do I get it?
  29. #789
    Freeport, ME
    artwork is avail from MadDog, just have to ask and sign a basic release... That's where I got the logo for my wheel centers
    Dan
  30. #790
    Huntsville, Al
    I am using a sample of the 3M carbon fiber wrap...I like it but it is my first try...it is pretty easy to work with and tolerates the heat gun very well. It is suitable for outside...that's what the package said anyway.
    The logo I had made online using the fonts from the company...was like $12.. nothing complicated. . it's a vinyl graphic.
  31. #791
    Eugene, OR, USA
    Thanks, I'll hit MadDog up!
  32. #792
    Encinitas, CA
    Looks great! I'm going to have to figure out something similar, since the standard console isn't wide enough for a DIN head unit, and I'd prefer not to mount it in the dash. (or sideways!)
  33. #793
    Huntsville, Al
    ok, so....I am going a little crazy with the wrap stuff...but it is sooo fun to work with and I still had some stuff left....so....more details....I even tried my hand at binding the carpet....didn't come out fantastic, but I think it is just passable.
    here is the pass side of the console...don't mind the finger prints
  34. #794
    Looking good Erik. I have to fab a console as well. I am doing something a little more simple. Just 3 gauges. Thanks for the photos.
  35. #795
    Huntsville, Al
    Dash and console all installed for the LAST time....let there be rock!
  36. #796
    Eugene, OR, USA
    Don't you mean, "Let there be Blues!"
  37. #797
    Feb 2013
    Eric, sorry for the late reaction to solution to the wire loom mess, but is that a Painless Circuit Harness? And, could you describe what you specifically did to the donor relay package to make it "Play Nice" with your aftermarket independent harness? I am going to the Electromotive Unit as well, so knowing how to make this chassis harness work effectively is a big solution at a reasonable cost. I believe the harness mess is a really big issue for those of us who are not electrical engineers!
    Again, thanks for your commitment to helping with all of this. BC
  38. #798
    Huntsville, Al
    BC,
    I got the harness from Wayne..it's not a painless, but similar...As far as making it play nice, I used one of the relay blocks from the donor and just wired it in via the schematics...wayne sells a ready to go kit..did you get the Electromotive from him?
  39. #799
    Feb 2013
    I am getting it from him and trying to understand all of the integrated pieces that I need. I am also planning an AIM digital Dash that plugs directly into the CAN port on the Electromotive. I think this is the cleanest package...expensive, but I can understand it and trouble shoot it in the future.
    PS, what crank pulley did you end up buying...to support the Electromotive Wheel?
    Thanks for the comeback. BC
  40. #800
    Huntsville, Al
    You need the stock pulley.
