![Midwest Classic Insurance](https://thefactoryfiveforum.com/attachment.php?attachmentid=40531&d=1428867682)
Boyd Tank / Not moving firewall back
Is the rear firewall required to be right in front of the tank to provide structural support? I have the Boyd tank, but it looks like I won't need the added leg room. So, if I install the firewall in the original location, there will be about 3" between the firewall and the tank. Would this cause any issues and are the supplied 2 bottom and 2 top bolts strong enough to fully support the tank?
Thanks!
Jerome
Won't be a problem. That's how I did mine.
818 builder
Ditto here, just bolt it in man, it won't go anywhere
![FFMetal](https://thefactoryfiveforum.com/attachment.php?attachmentid=195371&d=1707243047)
