Thread: First start...and..water in oil
    Well good news...bad news. I got the car started up ( ok ok...video is actually second start) but after running it found water in the oil. Now I'm trying to figure out if I have a intake gasket leak or timing cover leak. The timing cover will suck because getting the harmonic balancer off will really suck in the car.
    Anyways...here is a video of (2nd) start
    http://s1279.photobucket.com/user/bb...7b5af.mp4.html
    Senior Member kraftee's Avatar
    May 2013
    Gainesville, Florida
    ummmm. NORMALLY, when one finds water in the oil, the first assumed culprit is a leaky head gasket...
    "If everything seems to be coming your way, you're probably in the wrong lane."
    Well..that was a thought but I highly doubt it. It was a fresh rebuild..flat deck..flat heads..good gaskets and I tourqued the heads down right. And I doubt they would blow on a first start..with no forced induction.
    May 2013
    You're probably right - more than likely the intake. Unfortunately, I can't say the same for my engine. Against my better judgment, I decided NOT to take apart my donor motor. See my thread for today's carnage... Eric
    Aww..man that sucks...sorry to hear that. I didn't want to worry about the engine so I just rebuilt it. And I have always wanted to do it...so I gave it a shot. Now I'm just crossing my fingers I can figure out this water issue without ripping it out.
    Ok..all fixed. It was the intake manifold. I also replaced the lifters while I was at it. Sounds great. Just a couple small issues. Exhaust leak from the passenger header to downpipe connection and for some reason I am getting no power to the cooling fan..minor issues. Should be ready to go kart within the week
    20131202_175730_zpsd15072d5.mp4 Video by bbkkssv | Photobucket
    20131202_173348_zpsff3f9da0.mp4 Video by bbkkssv | Photobucket
    Horseheads, NY
    That sounds awesome....
