![FormaCars](https://thefactoryfiveforum.com/attachment.php?attachmentid=62553&d=1483735916)
C-5 Vs C-6
I apologize, I am sure this question has been asked and answered elsewhere in the forums, but I am not having any luck finding it. I am doing research on building a GTM and have some questions regarding chassis/suspension and various other components. Looking through the required parts list and with the understanding it is based off a C-5 platform, will components from a C-6 work the same? I.E.; control arms, brakes, parking brake, steering column, cooling system, ignition switch, throttle, wiring, fuel tanks, wiper motor, window regulators and all other sub-components and systems necessary to complete the build.
I plan to run an LS7 and with that, I would like to buy a salvaged C-6 for a donor and have everything I need for the build in one shot less the transaxle, instead of buying all the components separately.
So all that to ask, do I need to look into a C-5 donor and find my LS7 and computer/harness elsewhere or am I good to roll with a C-6?
Thank you very much for your time, It is appreciated.
Nate
Welcome to the forum Nate. I am sure some of the GTM builders will be able to answer your questions shortly.
Doug
Thank you for the warm welcome Doug
Hi Nate,
Your question has a very involved answer. You do need to post in the GTM forum to get the answer. The short answer is yes, with a few no's.
Start by looking at this awsome build, http://gtm410.com/
Good luck,
Gene
Hi Nate,
Welcome! Gene makes a good point. My advice is this: We designed the car around the C5 and didn't take a C6 apart to determine what would or wouldn't work, but I know that the spindles/brakes will work, and so will 2008 fuel tanks (maybe the whole range?). Either way, maybe some others from the GTM forum will have tried to use a C6 and can provide some more info.
Good luck!
Jason @ FFR
Thanks for the input Jason, I'll resubmit my question in the GTM fourm.
![Martin's Dent and Collision Shop](https://www.factoryfive.com/wp-content/uploads/2019/02/martins-dent-shop.jpg)
