Hey guys,
I just experienced this with my 33 and thought I'd put it up here. It appears most haven't had this issue thus far with the 33 but it's somewhat common for the roadster guys considering how much racing is done (and the sheer number of roadsters on the road). Bolting on the 3 link bracket is simply not enough. While some will say that cars with more torque than stock, drag race applications, etc, etc, will cause this, I'm hear to say that 300HP and 300 lb/ft appears to be enough to twist the rear into submission and bend the bracket. Personally, I bought a used rear end and I"m not sure how well it was treated before I got it but I think my axle housing may have twisted as well inside the pumpkin as I had tranny oil coming out the seam. You could see the paint was worn off and the bracket was twisting on the axle but I my have broken the tack welds on the axle/housing interface as well.
So, after doing the research on the roadster forums, it seems that Breeze and VPM have solutions for this. The VPM will work with the factory dog ears on the housing- but I cut these off. DOH!. As for the breeze method explained here http://www.breezeautomotive.com/imag...stallation.pdf, dependable sources are telling me that this much welding to the axle housing (pumpkin) can cause significant damage via heat and will take the axle out of alignment which can ruin the bearings and the driveshafts. So, I'm going to do a couple of tack welds at 180 from each other on the housing/axle interface. and then install the 3 link bracket and do a few tacks there as well. So I'll be doing a light weight version of the Breeze setup which will allow me to remove the bracket with an angle grinder if this should ever happen again.
I appreciate and welcome any input here. Wish me luck!
