0
0
G50 Transmission Use in the GTM / Oil Types and Levels
I know that for the GTM the Porsche G50 gets rolled over to make it work.
There is a vent at the top of the gear box that I assume will get put where the drain hole is and the vent hole now becomes the drain hole.. The fill hole is on the side of the gear box and when you roll the gear box upside down to put it in the GTM how do you check the oil level now that the hole is much higher that it was??
I see that the G50 holds 4 Qts of API Class GL5 75/90 Synthetic. I see there are several different brands, what is the best one to use??
Use one gallon of oil in the G50 gearbox, and a bit more if you are going to use a external pump and cooler.
Feel free to give me a call with any questions I can help with.
Erik Johnson
Do NOT use synthetic oil in the G50. The synchronizers will not last as long if you use synthetic oils. I would recommend pretty much any GL-5 oil. The Swepco oils work quite well but you will want to stick to 201 or 210.
Erik
