NASA has posted the 2014 Rules.
2014 Rules
2014 Rules
Brian [email protected]
Great Lakes & Midwest Region Series Director
Well looks like the rear gears stay the same as 2013, option for 30 lb./hr injectors of any brand and associated MAF, and the new RR's of same 2013 size.
#60
So we should not have to change MAF if we go to 30 lb injectors, I will most likely not go to 30 lbs unless the 24 lbs fail. I will go to the RRs even though they are little more expensive, as the RA-1 I would have to add $15 for shaving. So the RRs look like about $20 more per tire
Tony Nadalin
2018 SOVREN Big Bore Champion
2012 ICSCC ITE Class Champion
818R Build in progress
Yep..... RR is a better tire and does not need to be shaved. So cost increase is offset by the no shave.
I am changing to RC engineering 30 lb. injectors along with a 30 lb. MAF.
#60
Be sure to note that the MAF is spec'd in rule 10.2. It is not "open" like the injectors.
Got it...thanks Brian
