Results 1 to 5 of 5
Thread: Filler Cap Ring Separated
    Senior Member VD2021's Avatar
    Central, FL
    The ring on my filler caps are separated from the main body. You can see that there was not enough glue used to sufficiently hold this together. Can you replace these?
    R/s
    Vidal
    R/s
    Vidal
    CURRENT STATUS: Interior Rework and Bodywork.
    GenII GTM #331. Delivered (23/9/10)
    BUILD LOG AND WEBSITE:
    http://gtmbuild.weebly.com/ .
    Tech Manager, FFR
    Hi Vidal,
    I'll send you a quick email about that - it shouldn't separate and can be replaced.
    Jason @ FFR
    Central, FL
    Thanks. Both caps are the same. I did an inventory when I received my kit, but I didn't check them for problems.
    R/s
    Vidal
    R/s
    Vidal
    Murrieta, CA
    I have exactly the same problem, and I emailed FFR about it a couple weeks ago- no response yet.
    Member stang_killer's Avatar
    New Haven, IN
    Mine did the same thing. I just reglued it and moved on.
