Page 1 of 20 12311 ... LastLast
Results 1 to 40 of 779
Thread: 818Rasmus E Modified
    Senior Member Rasmus's Avatar
    Las Vegas, USA
    It begins.
    The parts from a 2006 WRX arrived today. The chitlins and I picked them up at the freight terminal. Two pallets of parts.
    Edmonton, Alberta
    Congrats
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
    QC, Canada
    Yeah another one!
    Any goals set so far?
    Tracked May 27/July 26, 2017
    Build Completed Winter 2021
    Mechie3's Avatar
    Indianapolis
    Goal 1: beat XP lotus
    Goal 2: see goal 1
    Zero Decibel Motorsports
    Check out my new website!
    Las Vegas, USA
    Goal 2: see goal 1
    I originally was shooting for E Modified. But when you see That Car, you realize just how small it is. You know that the 818 is too wide, too long, and too fat to have a chance even if you were the best driver in all of Solo.
    Aug 2012
    Long Island
    I see in your future...
    The lightest 818 so far!
    Congrats.
    Goal 2: see goal 1
    Freeport, ME
    Nice looking bug eye! I look forward to following your build... Mine will only be a part time autocrosser as I'm addicted to my DD2 shifter kart for autocross
    Dan
    Senior Member Mike N's Avatar
    Mooresville NC
    WOW! I wish you luck beating Fred Zust's Lotus, that is a highly developed car. Care to share some details of your plans? BTW, I understand your reluctance in taking on Jeff Kiesel.
    Mike............
    XP? Do you know something that I don't? Last I heard the SEB put the 818 into A Mod with the featherweight winged cars.
    Las Vegas, USA
    The SEB puts everything in AMod they haven't looked at closely enough. AMod just a place holder. The SEB wanted to actually see a few of these cars built before they made their decision. Initially, I wanted the 818 to class in EMod but when you see the over size go carts in that class you know the 818 is too wide, too long, and too heavy to compete. So I went back to the rulebook. And X Prepared has many Kit Cars already approved to run. Three of them are Factory Five cars. So it's my HOPE that the 818 is approved for XP.
    Plus the minimum weights in XP are on a sliding scale. Not tiered like EMod.
    Weights in XP are determined by several factors with the major factor being engine displacement with a 1.4 times adjustment for forced induction. The short of it being:
    Running RWD, engine behind driver, no ABS, no traction control, car with a 1.994L (92.00x75) turbo motor minimum weight would be 1815 lb.
    Running RWD, engine behind driver, no ABS, no traction control, car with a 2.333L (99.50x75) turbo motor minimum weight would be 1919 lb.
    Running RWD, engine behind driver, no ABS, no traction control, car with a 2.344L (99.75x75) turbo motor minimum weight would be 1923 lb.
    Running RWD, engine behind driver, no ABS, no traction control, car with a 2.457L (99.50x79) turbo motor minimum weight would be 1957 lb.
    My goal is the 2.344L turbo with min. weight 1923 lb. I'll have to add ballast.
    Yeah, I knew all that, just thought maybe something developed that I missed. I figure they'll hold it to AM for a season then slot it in to where it really belongs (XP, EM or ??). I agree that XP seems to be the most logical (however it has been proven time and again that "SCCA" and "logical" are often mutually exclusive ). Remember when looking at weight requirements that Prepared class car minimums are WITHOUT driver and Modified class minimums are WITH the driver.
    Las Vegas, USA
    Looks like this was once a World Rally Blue, 2006, WRX. Looks like it sold for salvage 2012, March 12th. And if I'm ever in a Speedway I won't have to fill out an application to get a 50% discount on Coco Puffs that have been marked up 100%.
    Aug 2012
    Long Island
    You should call up and see what "rewards" you have accumulated... If ever in Ohio you may be entitled to some nachos my friend!
    Feb 2013
    Westminster, MD
    This is a nice perk for us. We are racing XP and STR-3 but since P is without driver and STR is WITH we're golden. NASA dictates our weight.
    1951 with 245s and 221whp WITH driver means the 1815 weight for XP should be our goal and actually put us over for NASA @ 1995 with my fat a$$ in the car.
    Mocked up our Solo wheels yesterday
    Mooresville NC
    Quote Originally Posted by SixStar View Post
    MEATY...... How far are they going to stick out past the stock body? How far do they restrict turning radius? Having seen posts on here with far narrower wheel and tire set ups encountering interference with the frame or at least marginal clearance I have to wonder just how much effort that will take to make work.
    Mike............
    Feb 2013
    Westminster, MD
    Quote Originally Posted by Mike N View Post
    At some point you stop putting tires under the car and just start putting them on in Solo
    Hitting the frame isn't an issue, we'll need steering stops for sure, but in Solo if you're turning that much you're doing it wrong. I can get one full rotation of the steering wheel before contact, but keep in mind that's with no alignment, and I haven't put the caster bushings on yet either. We're toying with the idea of running the wagon mounts to get us a little more width too.
    Las Vegas, USA
    Spent half of yesterday and all of today pulling one third of my '68 Cadillac parts out of my shed. I hadn't organized the shed well; there was a bunch of space to be had with a proper resort.
    Fit two new shelving units inside the Shed of Shame. Both dedicated to 818R parts.
    Mechie3's Avatar
    Indianapolis
    Not much grass there huh.
    Las Vegas, USA
    Recreating Ireland in the desert requires water. Water you have to pay for and plumb for.
    Las Vegas, USA
    Sorted through things a bit more.
    That is one intimating box when opened.
    It contained the entire wiring harness from my donor.
    Plus ECU. 22611AL350 = Model Year 2006 WRX Sedan or Wagon
    Some parts are in rough shape.
    Transmission came from a different Subaru Model, by my request.
    TY757VWAAB = US Legacy Turbo Outback MY05-09. That's not what I requested. I wanted the TY757VBAAB = US Legacy Turbo GT MY05-07. The gear ratio's are the same inside both transmissions. It's the final drive that differs. The one I received (TY757VWAAB) has a 4.444 final drive. The one I wanted (TY757VBAAB) has a 4.111 final drive. Screws up my gearing estimates. For Solo, I don't ever want to shift to third. My estimate with 23.5" tall tires maxs me out a 73.6 mph in second with the 4.444 final. With the 4.111, second stretches to 79.5 mph. Knowing my local Solo courses are tight, I'm not sure yet if this is a good thing or a bad thing.
    Took much more time than I thought to get the motor onto the stand. But there it is.
    Mechie3's Avatar
    Indianapolis
    The wiring is less intimidating once it's all stretched out. In a huge bundles it's just a pile of "oh fudge".
    Freeport, ME
    what he said!
    Dan
    Exeter R.I
    Yea it is not horrible, just be careful to not cut too much
    Aug 2012
    Long Island
    You'd have more room if you got that 68 back on the frame
    Las Vegas, USA
    Zing!
    I refer to the '68 by two different names. If I've worked on it in the past 2 weeks it's "The Cadillac"; if more than two weeks have passed since last working on it, it's "The P.O.S." Pile Of Shame.
    Today, it's "The Cadillac".
    Freeport, ME
    Is that the big block 472 CI ERA?
    Everyone needs too many projects... its like a low grade fever that never goes away... (says the man with 119 pistons)
    Dan
    Las Vegas, USA
    Good eye there. I own both. The 472 that came with my '68 Cadillac Coupe deVille and a 500 in^3 that came out of a '74 Cadillac Eldorado. 500 in^3 = ~8.2 liters. That's over a liter per cylinder. I'll have to do a side by side picture of the Cad500 block and the EJ255 and then one of the two crankshafts.
    Las Vegas, USA
    Had the itch to get something done.
    Removed all three accessories and brackets, the G.B.O.D. (Green Brackets of Death), some tubes, and the upper coolant tank.
    No issues. No broken bolts. PB Blaster is my friend.
    Oil Fill tube didn't make it though. Looks like it snapped between palletting and arrival at the shipping terminal.
    Exeter R.I
    Those tubes always crack, and it sucks when you don't notice it
    Mechie3's Avatar
    Indianapolis
    I have billet oil fill tubes for sale (due in after xmas now.... ) or for cheap can sell you my stock oil fill tube (you'll need to reuse the o-ring on your stock one since I broke my experimenting).
    Las Vegas, USA
    The S.O.'s gift:
    Perfect. Spent hours putting it together. Dozens of 7mm nuts with separate washers can get bent. Only got one part wrong. Double caulked everything up; read they leaked a bit. Gonna need to purchase some more baking soda.
    Senior Member Xusia's Avatar
    Eugene, OR, USA
    That's awesome!
    Edmonton, Alberta
    I have the same cabinet, caulked it as well. I too was surprised at how tedious it was to put together. Congrats.
    818 SRX - #91
    Arrived 01/02/2014
    Freeport, ME
    use 3/16 pop rivets instead to speed up assy???
    Dan
    Edmonton, Alberta
    Thanks dan, where were you 4 months ago?
    818 SRX - #91
    Arrived 01/02/2014
    Freeport, ME
    1 I'm and engineer, problem soln is just a natural process
    2 I have MS and haven't had normal feeling in my fingers for almost 23 years... so I do threads as little as possible
    3 it is never coming apart, is it? if not why use screws
    Do yourself a favor and buy an air riveter, even the Harbor Freight one will improve your attitude during a big project (unless you want to build up Popeye forearms!)
    Dan
    Las Vegas, USA
    Oh, now comes the brilliant ideas! Yep 3/16 and 1/8 pop rivets in assorted grip lengths would have made this go faster. Especially for the main box and hopper. Pop riveting just those two (3/16" short grip) would have saved oodles of time.
    Las Vegas, USA
    This is the only time I'm gonna do this: show off parts before install. After this I'll only post them as I install. Pinky promise.
    But in this one case, I'm just so excited!
    Box came from Micah at 3MI Racing. Don't Jenga near the address label! Damn kids.
    Saenz Rods
    ~519 grams, including bolts
    Nice bolts. ARP L-19
    134.5 mm rod length Photo doesn't show it well. But you can read it on the box a few photos up.
    Look at that parting line
    Beautiful piece
    Las Vegas, USA
    JE, "Honey Badger" 99.75mm pistons. Developed by 3MI Racing and Maxwell Power Services.
    -18.2 cc chambers
    Works of art.
    ~394 grams
    ~107 gram, tool steel wrist pin. It's strangely heavy for how small it is. Dense.
    4.34mm (.170") wall
    QC, Canada
    This is a beauty!
    So maybe it's better not use it and just keep in your garage on a shelf as a trophy or piece of art. lolll
