Results 1 to 12 of 12
Thread: Garage Clean out - left over parts from 33 Hot Rod Build
    Member stang_killer's Avatar
    New Haven, IN
    Finally got around to Cleaning out the garage and shed.
    Prices do not include shipping. shipping from Indiana 46774
    Wilwood plastic reservoirs - $15 for pair
    Wilwood proportioning valve (used) $15
    New Haven, IN
    These are the original power window slides that cme with early kit. FFR went to remote mount motors, I cut one of the assemblies for the car 7 1/2 inches (Have cut piece could be welded back together. other is uncut. These were too tight for doors but would be great for different Hot rod. they come with floating window attach rollers and switches. I used the wiring for my install $100 for all of it.
    FFR supplied clutch quadrant for Wilwood pedal assembly includes firewall adjuster - $40
    New Haven, IN
    Coil over Springs
    pair QA1 9-180 $30
    UPR Bump Steer kit - Package was opened but never installed (decided I didnt want to drill my spindles for bolt) $70 - SOLD
    New Haven, IN
    older Early kit supplied Gas cap (It came apart once and was JB welded back together) ended up changing to different type fill - $25
    FFR supplied Stainless brake lines Banjo on one end and #3 flare on other 17" long pair - $30
    Edelbrock 750 Vaccum Secondary Electric Choke- used was on car for about 1500 miles I think it is a 1411. $150
    New Haven, IN
    IMG_0844.jpglastly some stereo gear I ended up not using
    MB Quart DTK-30 Tweeters - $30
    AudioBahn Crossovers - $20
    GM X562 Amp (130W) (I needed more channels than this had so never even powered it up ) $80
    Frankfort, IL
    How much including shipping for the cup holders and remote battery terminals to 60516? Happen to have a need for both!
    Senior Member maczter's Avatar
    Feb 2013
    Xenia, OH
    Swan mirrors and 24" brake lines to 45385. How do you want payment?
    Jack
    FFR HR #530
    Race car theme, Tim Whitaker roll bar, Autometer Autolite Gauges, Satin Black, SBC 383/700R4, 8.8 rear with Cobra Brakes, 3.29 gear, Boyd Tank, QA1 springs and shocks,
    My build blog: http://jacks33hotrod.blogspot.com/
    New Haven, IN
    PMs sent to maczter and billjr212.
    New Haven, IN
    Quote Originally Posted by maczter View Post
    Jack
    paypal is fine. Can do USPS flat rate shipping for $12 ([email protected])
    Senior Member MK4's Avatar
    St-Eustache
    Pm sent on wiper motors
    Major driving fun since may 2012!!!!!
    New Haven, IN
    TTT added edlebrock 750 carb
    Senior Member HookedonFord's Avatar
    Panhandle, FL
    Sent you a PM on Brake Lines. thanks, jim
