Results 1 to 3 of 3
Thread: New Aluminum LCA Question
    Senior Member Xusia's Avatar
    Eugene, OR, USA
    The ball joint on my new LCA doesn't move - even if I tap (not pound) it with a hammer. The ones off the donor moved easily. Am I being dense? What's wrong?
    Here's a pic of the part:
    Hey Xusia,
    New (good) ball joints are tight. The ones off your donor sound like they are bad.
    Compare the lower joints to the big upper joints supplied by FFR. I think you will find they are similar thghtness.
    Put a spindle on the lower arm. You should be able to bend it back and forth. The spindle will probably stand by itself with a new ball joint.
    Eugene, OR, USA
    OK then. I'll try that when I get to that point, and not worry about it until then. Thanks a bunch!
