Thread: found a heater from norhtern
    anderson
    [attach=config]25305[/attach)
    San Diego & Riverside CA
    Could that be plumbed from the radiator and placed in the front footwell?
    Dru
    anderson
    that is my plan for now
    I tried to find it. Can you give me more information or a link.
    Dru
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    You might want to also check out Vintage Air. I am leaning toward using their Gen II heater/defrost 906101. It's $229 from summit racing.
    Jan 2012
    Is anyone looking at ac/heater options??
    anderson
    San Jose, CA
    I'm still researching. If I don't find something else by the time I get to there, I was planning to use a Vintage Air system. If someone figures out a clean AC install, then I'll likely try to copy what they are doing.
    anderson
    if you look for a heater only the northern unit is smaller than the vintage air
