Results 1 to 6 of 6
Thread: Is a 2009 production drag radial too old to use?
    Cape Cod
    I can purchase (2) brand new BFGoodrich DR for under $300.00 for both shipped to my door. They have been stored indoors their entire life. They will be going on a 400whp car if that matters. Is 5 years old something I should be concerned with (safety and or performance)?
    Thanx in advance for the advise.
    Senior Member Boz1911's Avatar
    May 2013
    Peachtree City
    My personal opinion is that if they have been stored indoors and haven't been exposed to sunlight and they should be fine.
    Master Builder
    Long Island, NY
    Was just looking on line and depending on size, BFG's are reasonable and that might not be such a great deal. Yes you will save $$ but not that much. I would look into new price.
    first.
    Kenny
    Cape Cod
    Thx for the advise. I will look into the prices of brand new as well.
    These tires are being sold as old stock from a tire dealer.
    Freeport, ME
    Old tires get hard... Formula V (GRM did an eval) can bring them back but I'd look for newer date coses
    Dan
    Indianapolis/Beech Grove, IN
    2-3 years is generally as old as you want to go with performance tires. Especially so if they were not bagged/wrapped since new. Being stored indoors is good, but they will still continually outgas the natural oils and get harder over time. Once they get to a certain point, they will never soften up again as a good drag radial should...especially when you will be heat-cycling them on every run. They may work ok, but you will run out of heat cycles long before usable rubber
