Thread: What sway bar mounts?
    Senior Member AZPete's Avatar
    I know I've seen a post about buying sway bar mounts & bushings for mounting the sway bar, but I can't find it now. Please give me a link or some clue for mounting an 06 WRX sedan rear sway bar. Thanks!
    rori's Avatar
    Tulsa, OK
    I bought these, they fit perfect:
    http://www.ebay.com/itm/170773134309...84.m1439.l2649
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    My 2005 ones from my donor fit fine.
    Kirkland, WA
    Are folks using the stock rear sway bar? What about front?
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
    Senior Member Xusia's Avatar
    Eugene, OR, USA
    The stock [WRX] rear sway bar is used in the front suspension of the 818. The 818 does not use a sway bar in the rear.
    Jul 2012
    Encinitas, CA
    The stock 17mm sway bar from the rear of the donor is used in the front of the 818; I also used the Prothane Type A Brackets and bushing and it worked great for the bar off my 2006 WRX wagon donor. The rear of the 818 has no sway bar.
    Rori, thanks. I bought the mounts on ebay.
    Bay area, CA
    older WRX sedan uses 20mm in the back, PROTHANE 19-1119
    Feb 2013
    Bowling Green OHIO
    Quote Originally Posted by wleehendrick View Post
    i too have a 2006 wrx wagon donar. bent my oem brackets to fit the flat mount ffr provides but the passenger side of the sway bar is really tight with the other suspension parts.
    driver side has ok clearance:
    i have not done anything with my upper control arms so i can gain a little space there.....BTW where is a good starting point for the links of that upper control arm, the manual has very little info on adjustment, (pg 465 has info on toe,camber, and castor, but i have never done an alignment myself, just want to get it close to see if i need a different sway bar. i think the wagon has the extra bend to go around the muffler.
    thxs
    Doug
