RoKaNo,
Thanks for the heads up. I didn't speak to Jason. I figured they are probably getting fed up with continually having to deal with a problem where there is always one more. I will give him a call. So is it the "hat" down by the heim joint or is it both that you had replaced? I really want to lay this to rest finally so I want to make sure I have all the correct upgraded components.
Thank you, WEK.
