Code:
Attached Aluminum Panel List
#10 / 15022: Rear Cockpit Corner, Driver Side
View: standing on the driver side of car, looking toward the rear of the car, with your left hip next to the driver door hinge.
Top-side: clear
Bottom-side: over #31
Left-side: under #12
Right-side: clear
#11 / 15022: Rear Cockpit Corner, Passenger Side
View: standing on the passenger side of car, looking toward the rear of the car, with your right hip next to the passenger door hinge.
Top-side: clear
Bottom-side: over #32
Left-side: clear
Right-side: under #12
#12 / 10823: Rear Cockpit Vertical Wall Behind Seats
Top-side: clear
Bottom-side-right: over #31
Bottom-side-left: over #31
Left-side: over #32
Right-side: over #11
#14 / 12985: Driver Side Dropped Floor.
View: standing on the driver side of car, stooped over looking into the driver cockpit toward the front of the car, with your left hip next to the driver door hinge.
Top-side (toward front of car): under #15
Bottom-side: clear.
Left-side: under #17
Right-side: clear.
#15 / 14733: Driver Footbox, Front Wall, Patch Panel
View: standing with your left hip next to the engine bay facing toward the rear of the car.
Top-side-right: over #18
Top-side-left: over #29
Bottom: over #14
Left-side-upper: under #30
Left-side-lower: over #30
Right-side: over #17.
#17 / 10554: Driver Footbox, Front Walls, Outside
View: standing next to driver side of car facing toward passenger side, with your with your right hip one step back from the driver door hinge.
Top-side: over #18
Bottom-side: over #14
Left-side: under #15
Right-side: clear
#18 / 10858: Driver Footbox, Top Outside Section
View: standing next to driver side of car facing toward passenger side, with your left hand side toward the front of car.
Top-side: under #29
Bottom-side: under #17
Right-side: clear
#19 / 10863: Engine Bay "F" Right
Clear on all sides
#20 / 10864: Engine Bay "F" Right
Clear on all sides
#21 / 15015: Right Footbox, Top/Outside, Passenger
View: standing with your right hip next to the engine bay facing toward the rear of the car.
Bottom-side: under #26
Left-side: over #35
Right-side: over #33
#22 / 15223: Trunk Wall (Driver Side)
View: standing directly behind the car, angled at a 45-degree angle toward the driver side
Top-side: clear
Bottom-side: #23 passes to the side of it, but doesn't overlap, strictly speaking
Right-side: clear
#22 / 15223: Trunk Wall (Passenger Side)
View: standing directly behind the car, angled at a 45-degree angle toward the passenger side
Top-side: clear
Left-side: clear
#23 / 15222: Rear Trunk Floor
View: standing directly behind the car, facing toward the front.
Top-side: under #25
Bottom-side: clear
Left-side: #22 (driver side) passes to the side of it, but doesn't overlap, strictly speaking
Right-side: #22 (passenger side) passes to the side of it, but doesn't overlap, strictly speaking
#25 / 10560: Front Trunk Floor
Top-side: clear, but abuts #12 without going over or under
Bottom-side: over #23
Left-side: over #39, and also over an unnumbered free-floating patch panel.
Right-side: over #38, and also over an unnumbered free-floating patch panel.
#26 / 13138: Passenger Footbox, Vertical Wall, Front Wall
Top-side-left: over #21
Top-side-rightx: over #33
Bottom-side: over #27
Left-side: over #35
Right-side: under #36
#27 / 13634: Passenger Footbox, Dropped Floor
View: standing on the passenger side of car, stooped over looking into the passenger cockpit toward the front of the car, with your right hip next to the passenger door hinge.
Top-side: over #26
Bottom-side: clear
Left-side: over #36
Right-side: under #35
#29 / 10859: Driver Footbox, Top, Inside
Top-side: under #30
Bottom-side: over #18
Right-side: abut #28
#30 / 10905: Driver Footbox, Vertical Wall, Inside
View: standing on the passenger side of car, looking toward the driver side, with your left hip next to the passenger door hinge.
Top-side: over #29
Right-side-upper: over #15
Right-side-lower: under #15
Right-side: under #34
#31 / 10557: Cockpit Floor, Driver Side, w/ Tunnel Wall
View: standing on the driver side of car, facing toward the front of the car, with your right hip next to the roll bar support.
Top-side (toward front of car): mostly clear, except for corner near transmission tunnel, where it goes under #30.
Bottom-side: under #10 and #22.
Left-side: clear
Right-side: mostly clear, except for edge near the front part of the transmission tunnel, where it goes over #34.
#32 / 10558: Cockpit Floor, Passenger Side, w/ Tunnel Wall
View: standing on the passenger side of car, facing toward the front of the car, with your left hip next to the roll bar support.
Top-side: clear
Bottom-side: under #11 and #12
Left-side: clear
#33 / 10853: Passenger Footbox, Top
Top-side: clear
Left-side: under #21
Right-side: clear
#34 / 12806: Trans Tunnel, Front Vertical Wall
View: standing on the driver side of car, facing toward the firewall, with your right hip next to the roll bar support.
Top-side: clear
Bottom-side: clear
Left-side-inner-bottom-two-thirds in corner near transmission tunnel: under #31.
Left-side-outer: under #31.
Right-side: under #30, and on the very bottom, under #31.
#35 / 10551: Passenger Footbox, Vertical Wall, Outside
View: standing next to passenger side of car facing toward driver side, with your left hip one step back from the passenger door hinge.
Top-side: under #21
Left-side: clear
Right-side: over #32
#36 / 13139: Passenger Footbox, Vertical Wall, Inside
Top-side: under #33
Left-side: over #26
#38 / 15403: Outside Trunk Wall, Right
View: standing one step back from the rear passenger-side wheel well, looking toward the driver side
Top-side: clear
Bottom-side: under #25, as far as #25 goes
Left-side: clear
Right-side: clear
#39 / 15402: Outside Trunk Wall, Left
View: standing one step back from the rear driver-side wheel well, looking toward the passenger side
Top-side: clear
Left-side: clear
Right-side: clear
#45 / No part number: Panel on passenger side, right above passenger door hinge, next to firewall
Clear on all sides
