Results 1 to 6 of 6
Thread: AOD cooling lines
    Senior Member hdnik's Avatar
    Welland, Ontario Canada
    AOD cooling lines
    I need to run trans oil cooling lines. I can't find or remember seeing if any fittings for the rad were sent or not. That's one. Next is what type of line is recommended. Steel or can I use rubber or braided lines. Finally fitting sizes.
    Help
    Nick Sebastian - 33 Hot Rod #495
    Factory Five Forums - hdnik
    FFCars - lowntubd
    Build Site/Blog - www.nicks33hotrod.com
    Senior Member maczter's Avatar
    Feb 2013
    Xenia, OH
    There are no fittings in the kit, I believe they are 3/8" npt. Yes, you can use braided lines (I am with my SBC and 700R) and you can use rubber IF they are high pressure lines, like fuel injection. If you are using rubber lines, a trick from my drag racing days was to use 2 hose clamps clocked opposite to ensure you don't blow one off during hard acceleration.
    FFR HR #530
    Race car theme, Tim Whitaker roll bar, Autometer Autolite Gauges, Satin Black, SBC 383/700R4, 8.8 rear with Cobra Brakes, 3.29 gear, Boyd Tank, QA1 springs and shocks,
    My build blog: http://jacks33hotrod.blogspot.com/
    Ponte Vedra Beach Florida
    For my Ford AOD I bought JEG's stainless trans cooling line kit (Specified for a 350 TH) and the individual -6 AN fittings. Problem is the advice from several folks have me with the wrong AOD fitting size. It's a METRIC Trans. Advice was 1/4"NPT. Wrong. Anyone know what's correct?
    Feb 2013
    Xenia, OH
    This page shows them as 1/4 NPT...
    http://www.tciauto.com/tc/cooler-fittings
    FFR HR #530
    1/4" npt here. Not sure why yours would be different.
    FFCars - lowntubd
    Fresno, CA
    Went out to the garage and looked at mine, 1/4" NPT
