![Midwest Classic Insurance](https://thefactoryfiveforum.com/attachment.php?attachmentid=40531&d=1428867682)
Russ Thompson turn signal wiring
I started wiring the Russ Thompson turn signal last weekend, and everything went pretty smooth although I do have a few questions on one thing.
I used the schematic shown below, and on the on the 4 count terminal connector next to the "blue" connector from the RF harness it shows a black wire that says: "To headlight switch feed 2"
![](http://i956.photobucket.com/albums/ae46/jdcoupe1969/2014-02-17RTschematic_zps9e735dd2.jpg)
Questions:
1. Is this supposed to be an existing wire or a new wire I need to make?
2. What gauge wire should I used if it is a new wire?
3. I used 18gauge wire for all the other connections and loops is that sufficient?
Thanks for the help,
90 views but no answers? ![Confused](images/smilies/confused.png)
Somebody out there has to have done this before!
John I don't have the RT turn signal switch (wish I did) but I do have the RF harness and the wiring diagram shows that the head light switch has two RED wires labeled HDLT SW 1 FEED and HDLT SW 2 FEED. Take a look at the wires and match the gauge. I would guess 14 gauge. I recommend you get on the RF website and ask a tech question about the gauge wire. Wish I could be more help.
![Replica Parts](https://www.factoryfive.com/wp-content/uploads/2015/04/replicaparts.gif)
