After a ton of looking, I found a 2002 silver WRX sedan about 2.5 miles from my apartment complex, and maybe 15 from the garage I'm doing the build in (a friend's house).
Motor:
EJ257 block
'10 STi nitride treated crankshaft
Wiseco pistons
Eagle rods
Acl main and rod bearing
ARP head studs
Ej205 heads
Ferrea valves
Combustion chambers custom cnc'd for larger bore
VF39 turbo
Walbro fuel pump
Deatschwerks 650cc injectors
TGV deletes
FMS 3" turbo inlet
Turboxs fmic and recirculating bov
12mm oil pump
New OEM water pump
Full 3in catless turbo back exhaust and catless up pipe.
Transmission:
Exedy stage 1 clutch
Gruppe-S flywheel
Bent 1-2 selector fork :'(
Supposidly JDM micro polished gearset. We shall see when the transmission gets rebuilt
Body is a 2002 silver WRX sedan in pretty good shape. Has full interior (which is mostly ricer-blue...... ) and gauges. It's also really close which is ideal for moving it. Guy has tons of pictures and receipts for all the work. Motor ran nicely and everything looks good so far. I'm hoping it's actually the deal I think it is at $4,800.
My small collection of WRXs
