Thread: 33 Hot Rod
    Mar 2014
    33 Hot Rod
    Anybody live near Portland Oregon have a 33 Hot Rod?
    I would like to see one in person before I travel all the way back to the factory
    Thank You
    Gordon Smith
    Senior Member esff32's Avatar
    La Verne, Ca
    rcotner on this forum lives in Wilsonville OR. Not sure if that is close to you but he is building a beautiful '33. His name is Ray and I'm sure he would love to show it off. Give him a shout. If you are going to be in So. California at any time, You are more than welcome to check mine out. Good luck.
    Evan
    Fresno, CA
    Welcome Gordon. I am not in Oregon but if you are ever down to the Fresno area I would be glad to talk with you.
    Doug
    Senior Member H R Lucky's Avatar
    Jun 2012
    CrossRoads, Pa.
    33 in Washington
    according to the FFR Google map, there are 3 Hot Rods being built in Oregon State, 1 near Portland, 1 in the Albany area and 1 near Roseburg.
    Here is a link to the FFR goggle map: https://maps.google.com/maps/ms?ie=U...z=4&dg=feature
    Nevin, AKA H. R. Lucky
    33 Hot Rod sn 524 build started 3/18/2013, First Start-5/09/2015, Go Cart-6/01/2015
    5.0 Coyote engine, 9in. Ford rear, 4 Link, Wilwood 12in. front brakes
    AC, power steering, FFR 17/18in. Hot Rod wheels
    Jun 2012
    CrossRoads, Pa.
    Quote Originally Posted by 68GT500MAN View Post
    Doug
    Doug,
    According to the FFR Google map, there is a guy with the same screen name as you located in Wyoming building HR no. 058. Is that you or did you move to Fresno? Just curious.
    Fresno, CA
    No, I have always lived in Fresno. I ended up with HR-058 and have not put much time into the project for the past three years. Right now I am in the process of re-building the engine in my roadster and then will get back onto the hot rod. It sounds like I will have to get Google Map corrected.
    Doug
