Page 5 of 20 FirstFirst ... 3456715 ... LastLast
Results 161 to 200 of 779
Thread: 818Rasmus E Modified
  1. #161
    Senior Member Rasmus's Avatar
    Las Vegas, USA
    Heads came off today.
    Organizing what came off and from where.
  2. #162
    Aug 2013
    and all the buckets in a bag... not going to be fun remembering where they all went.
  3. #163
    Las Vegas, USA
    Quote Originally Posted by icky View Post
    All valves and cam's will be removed and replaced with different ones. Thus the buckets are all in one bag. Some of them might even be the correct thickness for the new cams and valves, so I kept them all. I promised not to show parts I haven't installed or worked on so it hasn't' come up in my build thread.
  4. #164
    south-central CT
    I mentioned this (with a picture) on FFRSpec72's build thread. You might want to get a Subaru water pump PN 21111AA026 as it will perform better than those with stamped vanes or paddles.
    Not sure if my EJ257 DAVCS head buckets will fit, but I'd be happy to help out if I can. I have a lot of buckets and they're not cheap! I know tipping the valve stems to get there or get close is common. Not sure how much of a pain that is. My machine shop did that for me when they did a valve job, but I still required quite a few new buckets. My last heads were totally set up for me with the 272 cams.
    That motor looks like it was a two pack a day smoker.
  5. #165
    Las Vegas, USA
    It probably won't make any difference to how your stock engine cools, but the Subaru water pump PN 21111AA026 performs better than the Gates pump or others with the "open paddle wheel" design as is the pump on the right in the picture.
    Attachment 26632
    Thanks for reminding me. I'd forgotten that water pump existed.
    And Scargo I will take you up on the used shim-less buckets. Even if it's only one or two. I have to get to that point though. If I recall correctly shimming out the cams is second to last step before putting the valve covers on.
  6. #166
    south-central CT
    You could say that. I honestly don't know the procedure my guy used, but head work is his specialty. They were slightly used heads (was really lucky to find DAVCS heads with 4K miles on them). When he adjusted the lash, I don't know if he bolted the heads up to anything or not. He had it all together at one point; I just have to take it apart enough to get the head bolts in.
  7. #167
    Aug 2013
    Quote Originally Posted by Rasmus View Post
    Sound about right, since you're probably going to need a lot of buckets, find a subaru guy in your area to trade with instead of buying new ones or worse, shaving metal off the valve stems into your freshly applied assembly lube! Make friends with people that build motors and they will be happy to help you out. Also In a pinch, you grind the bottom of the buckets not valves, cheaper replacement and you can do it away from a motor that is being assembled but it is still advised to just find the right buckets from the beginning.
  8. #168
    Las Vegas, USA
    ...it is still advised to just find the right buckets from the beginning.
    That's the route I'm going. Just going to get the correct buckets the first time.
    Split the case today. And I'm happy to report not a single screwdriver, chisel, or wedge-shaped tool was used.
    I cut the heads off two old case bolts I had from another block. Rounded off the cuts. Then stuck those into the wristpins, just far not to extend out the other end of the wrist pin. Used two small scraps of aluminum to protect the threads on the wrist pin access hole. Then just put a 22mm 1/2" drive socket on the crank pulley bolt and pull 'til the case splits.
    Do the same on the other side. Then repeat and you'll walk the case off the hollow locating dowels.
  9. #169
    Las Vegas, USA
    Don't get to far because you still need to get the wrist pins out. Pistons come out the top. It's easier just to pull (actually push) all four wrist pins first with a case flip inbetween. Then pull a case half off with the pistons still stuck inside.
    Really starting to look like the previous owner of this block did not like changing the oil.
    Pistons 1 and 3 had heavy carbon build ups.
  10. #170
    Aug 2012
    Long Island
    impressive that your o rings all stuck to the same side.
  11. #171
    Freeport, ME
    Any idea how many miles on that 2.5L donor motor? The photos don't look that bad to my eye for a 100,000 mile plus motor...
    Dan
  12. #172
    Las Vegas, USA
    And there's been no manipulating of the o-rings for a "pretty picture". I would never pose my parts or hide my mistakes though carefully selected camera angles. This build is all about truth. Raw unedited truth. And justice. It's a bit about justice. And freedom. Freedom, to be who we to be. To do what we want to do. A stick-it-to-the-man build.
    /sarcasm
    I don't. I could hook up the cluster, but that just seems like too much work.
  13. #173
    Aug 2012
    Long Island
    And freedom.
    Amen Brother.
  14. #174
    Las Vegas, USA
    On Thursday March 6th, this thread, my build, and my activity will go dark for 3 - 8 weeks.
    Shoulder surgery - dominate arm. I tore my bicep, 3 weeks ago. A "SLAP tear". I just got word today that the O.R. got room and I'm on the schedule. Sucks getting old, but it's better than the alternative. I just called Stewart Transport and had them delay my delivery until the first week in April.
    Cool thing is medical science is advanced enough to fix me. Science, *****! And I'll have a titanium screw in me.
  15. #175
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    Sorry to hear about your injury. I pray that your surgery and recovery will go as planned.
    Larry
  16. #176
    Best of luck with surgery and recovery. Looking forward to your getting well and back to work.
  17. #177
    Feb 2013
    Westminster, MD
    Tip on the cam caps, they're all labeled so you can't really mix them up assuming you only have one motor torn down at a time.
  18. #178
    Senior Member DodgyTim's Avatar
    Brisbane, Australia
    Sorry to hear about your arm bloke, you'll have to learn to type one handed, and live vicariously through everyone else's build threads
  19. #179
    south-central CT
    What a slacker. Get's all this stuff going and skips out. Who will lead us and show us the way?
    I feel the same way. Old is better than the alternative. Like... halitosis is better than no breath at all.
    I expect to see great things when you are well. Don't be a stranger.
  20. #180
    Hey Ramus
    You may not get a lot done on your project. I will bet you will still be able to help others.
    Good luck and take care.
    Hang tough Rasmus,,,,,,,
    Good luck with the surgery.
    We'll be thinking of you ! ! !
  22. #182
    Nov 2012
    Medina, OH
    I hope you have a successful surgery and a quick recovery. Heal it right, you'll have trouble enjoying the drive in your 818 with a painful arm.
  23. #183
    QC, Canada
    So who's going to clean all your parts?? lolll
    Seriously, I'm sure it'll all go well, if you trust your mechanic, the repairs will be good enough for another 100k miles at least (that is the warranty)... who many you got on your counter? Naaah, not "that" old. Just make sure you don't smoke, then carbon will not build up.
    Tracked May 27/July 26, 2017
    Build Completed Winter 2021
  24. #184
    Chicago, IL
    We're all getting older, so show us how to do it right! Speedy recovery to you...
    Remember, it only takes one hand to type.
    Best,
    -j
    Executive Director
    The Community Garage
  25. #185
    Senior Member Xusia's Avatar
    Eugene, OR, USA
    That sucks. Speedy recovery dude.
  26. #186
    Senior Member gwarden's Avatar
    Jan 2012
    Surry Va
    Good luck with your shoulder
  27. #187
    Aug 2012
    Long Island
    hmmm right about the time you were trying to get those long bolts out...
    SUUUUURE take the picture in front of the press, they wont suspect anything... we all know now you were using your bare hands. LOL
    Feel better soon.
  28. #188
    Freeport, ME
    As someone who went through a detached retina, a severe infection and two "threw my back episodes" since beginning my build I can relate... It's tough to let a fun project sit, but hang in there. I'll miss your updates...
    Dan
  29. #189
    Senior Member AZPete's Avatar
    Best of luck, Rasmus. Please keep helping us when you can. At least you're getting a lightweight titanium screw!
  30. #190
    Feb 2014
    Asheville, NC
    Good luck, Rasmus! You got this! We'll catch you when you get back!
  31. #191
    Exeter R.I
    Good luck
  32. #192
    Frankfort, IL
    i strained a bicep last week trying to put my snowboard in the attic like an idiot and thought for about 24 hours that I had done something worse, so your post is making me cringe (I lucked out).
    Best of luck with the surgery and hope you have a speedy recovery!!
  33. #193
    Las Vegas, USA
    Thanks for all the well-wishing fellas.
    Be right back.
  34. #194
    Las Vegas, USA
    Success!
  35. #195
    Edmonton, Alberta
    Happy to hear, get well soon!
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
  36. #196
    Eugene, OR, USA
    Lookin' good! You'll be back to work on your car in no time!
  37. #197
    Jul 2012
    Encinitas, CA
    Best wishes for a speedy recovery! Get it moving/working and on PT ASAP.
  38. #198
    Las Vegas, USA
    My medical staples are starting to itch. Typing one handed sucks. Wah!
    A Flat4 forum member sold me one of his 1997 Legacy Knuckles to replace the one I cracked. Should be here next week. Looks like the de-rusting bucket has another customer.
  39. #199
    Exeter R.I
    My bro had the same thing done, two-three months you should be doing great.
  40. #200
    south-central CT
    My medical staples are starting to itch. Typing one handed sucks. Wah! Looks like the de-rusting bucket has another customer.
    And picking your nose is hard too, right? I've taken stitches out but I don't know if I could do staples. Oh, that upright looks cherry!
