Does the complete kit come with a gas tank shield? I'm ordering stuff online and don't remember seeing a shield, unless it shipped inside the gas tank box, which I haven't opened...
Good question David. Are you are referring to the plastic cover that covers the gas tank?
Doug
Just over at the factory website and looked up the complete kit information for fuel system. There is NO mention of the cover listed.
Doug
Yes. I believe it does.
It's included. I use them for the same reason that Ford did; to add a measure of protection from road debris to the tank.
Thanks guys. I'll assume it's in the tank box then. I appreciate the help!
It comes in the box with the tank
Mine was on the truck without a box. The driver ask me what it was for as he hadn't seen one before. Maybe my stuff was packed a little different.
King
yes in the box with the tank
Bill3422
MK4 - 302/347 Stroker - AFR Heads - 400 Hp
Comfirmed, mine is in the box.
