The kit is finalized and ready for orders. Comes complete with all the T-bolt clamps, Bosch water pump, large heat exchanger, fittings, hose clamps, BOV/BPV, coolant hose and intercooler core. The AWIC will give lower intake temps than the stock air to air intercooler. $1400 plus shipping.
IC core bleed valve installed. Allows you to make sure there is no trapped air in the IC core. Simply run the pump and loossen bleeder until coolant comes out then close bleeder. Top off radiator.
Tool less bleed valve option (Add $10)
