Thanks guys for commenting and expressing your views. We are all (mostly) learning here and all want the best results we can achieve and I believe to help our fellow builders.
FYI, the closest I've been to working with fiberglass is on my sons and I project '77 Vette. It only had a 1" long crack/blemish that repaired before starting the painting process. So realize I basically know nothing about fiberglass repair.
Today I went to Fiberglass Hawaii, they seem to know what they are doing and have a pretty large operation and were very busy. Car guys, boat guys, and surfers all in line buying and asking questions. Dutch the Operations Manager assisted me. So here is what I bought
And to get an idea of cost here is the list
As you can see I purchased vinyl ester resin. This is not readily sold on the counter, he filled a gallon container for me from the warehouse (smallest amount they would sell). He said I would have been fine with using polyester based resin (at less cost), but that the vinyl ester does have some corrosive resistant properties. I told him I wasn't really concerned about the extra cost, that I wanted to make sure I didn't have a problem showing up in the paint a year to two from now.
He told me that for patches to lay up 4-5 layers of the mat, about 45-60 mins apart to get to the same thickness as the FFR body parts. Clean everything with Acetone.
I am going to cut out the vent area of the trunk lid and replace with flat fiberglass, so he sold me some Mylar sheeting to use as a "form" as the resin will not stick to it.
I will also be adding some layers of fiberglass in a few areas to strengthen. I will post pics as I get into it.
So please comment as you see fit so we can all learn, thanks in advance.
