Results 1 to 11 of 11
Thread: Newbie in Arizona
    Mar 2014
    Newbie in Arizona
    Very excited wingnut in Arizona who is digging up as much information I can about the 33. I really like the looks and the potential. I have done a couple of projects, mostly old iron 55 GMC Carryall and 56 GMC short bed. I need this car to be comfortable if there is any hope that el jefe Grande (Diane, my wife) will be part of this. Think we both are ready for a smooth ride in our project, all of our previous projects, well rode like trucks. Anyway, comfort speed and air condition are on the list so far. I would like to hear from the 33 folks about the ride and if anyone has installed A/C. Anybody in the Phoenix area that might let me come take a look?
    Wingnut
    Feb 2014
    good luck wing nut! I live in Western NE and have made the same request....no responses.
    Super Moderator
    Ray's Avatar
    La Mesa, California
    Chuck Armstrong has built a multi-award winning '33 and he lives in the Scottsdale area (I think.) You should also talk with Gordon Levy down in Maricopa. He's built several '33 (as well as everything else FFR produces) and can give you both some extremely valuable guidance to make your car do/ride like you want.
    Good luck and welcome to the Forum.
    Ray
    Senior Member kraftee's Avatar
    May 2013
    Gainesville, Florida
    If you want a comfy ride, stay away from the "rubber band" ultra low profile tire/wheel combos that seem to be so popular. Good old 15" wheels with big rubber will help the ride a bunch. I went with Summit Pulsars and Mickey Thompson Sportsman S/R Radials.
    "If everything seems to be coming your way, you're probably in the wrong lane."
    Wisconsin
    For ride comfort, you'll want softer springs, better adjustable shocks and to compensate for the lower spring rate, you'll want to add front and rear anti-sway bars. You can make it ride as nice as a stock Miata MX5 if you work this general formula. There are many of us with tender backsides that have worked out most of the part selection.
    Best regards, Tom
    Wink ride details 33HR vs 33SR
    Quote Originally Posted by Wingnut View Post
    Think we both are ready for a smooth ride in our project, all of our previous projects, well rode like trucks. Wingnut
    Wingnut
    The 33Hot Rod has AC as an option from FF but some have added their own AC after the fact.
    On the "smooth ride" issue, most buyers either like the stiff/Race suspension as it comes or they
    change all the shocks and springs and some even go soft enough that they add sway bars as well.
    If you are looking for the comfy cruiser you might not want the 5 point harness that FF includes.
    A lot of folks have said the side exhaust is too loud and pulls fumes into the cab while cruising, so the rear
    exit exhaust would likely fit your plan better. I jokingly call the stock sprung kit a 33 (H)arsh (R)ide
    and the re-worked ones a 33SR (S)oft (R)ide or Street-Ride .
    Dale Berry
    Hemi33SR
    Quote Originally Posted by shifty View Post
    Shifty
    Sorry we didn't notice your post, anything I can answer for you now?
    Dale
    Fresno, CA
    Welcome to the forum. Come on over to the annual gathering of FFR builders in Huntington Beach, CA on April 26th this year. There should be many examples of the 33 in attendance.
    Doug
    Feb 2014
    thanks myjones. I am learning a lot from everyones posts. Good one here bout softening up the ride. We put lots of miles on our cruisers and like a decent ride. Some concern here about interior room and getting in and out.. My old bones don't bend as much as the used to!!!
    Fort Lauderdale Fl.
    Welcome to the madness!!
    FFR Daytona Type 65 Coupe
    67 427 Cobra
    57' Belair
    34 5 window coupe Ford
    2003 Mustang GT
    99' ZX9
    85 Goldwing
    Entry and exit is pretty good with the 33. Especially with no top.
    I've not had too much problem with the side exhaust fumes on either one of my Cobras but noise can be an issue. I like the side pipes, so put them on the 33. it will have electric cut outs to divert to an optional rear exhaust for long rides.
    Shocks are an important consideration with the 33 but wheels make as much if not more. my 15" wheels on my Cobra make it ride like a caddy compared to the 17's i used to run.
