Results 1 to 11 of 11
Thread: see what one man can do in thrty days -- 818 S
    anderson
    I received my chassis on 3/15/2014
    I have been working on it every day since then.
    it's really fun compared to restoring a rusty old clunker
    It does not take a year to find parts and then try to restore them back to new is a pain
    see here what i did in the last 30 days
    http://s993.photobucket.com/user/rim...d2c4d.jpg.html http://s993.photobucket.com/user/rim...83105.jpg.html http://s993.photobucket.com/user/rim...67061.jpg.html
    Kirkland, WA
    Very nice ! Did you leave the middle of the rear firewall open (middle triangle space)? Also did you use steel or aluminum ?
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
    San Jose, CA
    Wow that is awesome! I received mine a week later and am in the process to spending the better part of 5 weeks on the road thinking about making this much progress. Keep posting, we want to follow along.
    Chicago, IL
    I like the raised center tunnel - looks like it'll have an interesting shape when finished.
    Curious though, why do you have so much of the corrugated tubing along the side? Didn't your kit come with the solid tube to lay along the side?
    Is that an AC/heat box you have mounted there? Looks like you've got some nice personal touches here.
    Best,
    -j
    Executive Director
    The Community Garage
    Senior Member Xusia's Avatar
    Eugene, OR, USA
    I like the raised tunnel as well. Good spot for storage!
    Have you seen the 818 Registry on Google Maps?? https://www.google.com/maps/ms?msid=...a=0&dg=feature
    Want your 818 added to the Registry? https://docs.google.com/forms/d/1zmF...rNCY4/viewform
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    Best,
    -j
    Uh check pic #2 with the tubing cut...
    anderson
    Waiting on rivnuts to mount the solid tube. Then I will cut the flex tube to correct lenght
    anderson
    Alum panels
    what was your donor? I just notices the rear drums. If those work, im all for it since maybe i can get a cheaper donor. I plan on doing a NA build
    anderson
    2002 n/a subaru impreza ts wagon
    anderson
    waiting tosee what all has to pass thru before installing the last alum pc also waiting on gas tank since i am raising it 3 "
