Page 24 of 26 FirstFirst ... 142223242526 LastLast
Results 921 to 960 of 1011
Thread: Wayne Presley/VeryCoolParts Build Thread H6 power
  1. #921
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    Ok so I suck compared to adubbelde and bompus sucks compared to me
  2. #922
    Member Slatt's Avatar
    Anchorage, AK
    Boy the weather has sucked here lately, had 3 days of sun this month, Spring can't come soon enough, I want to drive this thing!
    I don't understand. It has headlights, right?
  3. #923
    Administrator
    Enterprise Alabama
    Maybe, just maybe I'll get to spend some time working on this car soon and get it on the dyno..
  4. #924
    Edmonton, Alberta
    Such a tease...
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
  5. #925
    Member Hayai's Avatar
    Boston
    I cant wait to see more videos.
  6. #926
    Feb 2013
    Copperas Cove, Texas
    Wayne you have a pm.
    -Jason
  7. #927
    Administrator
    Enterprise Alabama
    I took some time last night after work to do some finishing touches on my car. I got some black Quik-Latches, these are the newest ones and have 25% more holding strength than the originals. Put them in and they look great.
  8. #928
    Clovis, Ca
    Very nice. What is the pull weight rated at?
    Thanks- Chad
  9. #929
    Tucson, AZ
    Are those the mini's (1.23in diameter) or the low profile (2.5in diameter) ? I really like these over the AeroCatch I was planning. The only downside to these are no locking mechanism, but they sure look nice and simple.
  10. #930
    Senior Member AZPete's Avatar
    Wayne, I like the black Quik-Latches. Do you think they could be painted to make them disappear?
    BTW, last night I was fondling the cool billet shifter you sent. Thanks.
  11. #931
    Administrator
    Enterprise Alabama
    Those are pull rated at 250 lbs
    Quote Originally Posted by bompus View Post
    These are the mini's
    They are available powdercoated so I would say yes.
  12. #932
    Member kabacj's Avatar
    Those look awesome Wayne. Do you sell those too? I need a set.
    XTF #2
    build start date June 19 2023
    GTM # 344
    Build Start December 2010
    First track day April 2013
  13. #933
    Administrator
    Enterprise Alabama
    You can order them from Summit QL-25-S, QL-25-SB black, QL-25-SP polished
  14. #934
    Freeport, ME
    you didn't use the optional "pockets" did you?
    Dan
  15. #935
    Administrator
    Enterprise Alabama
    ???? Optional pockets?
  16. #936
    I have been running quick latches on my Evo since they debuted years ago.
    They technically CAN be painted, however the clearance between the button and the housing is very very tight. I am planning on painting a set soon, but I will lightly turn down the button a few thousanths for clearance.
    The only problem I have had on them, is that in cold weather they freeze. I had a battery die in cold weather, and had to buy two cups of McDonalds coffee to pour onto the latches to defrost them to open them.
    The buckets ("pockets") are designed for flush mount of the pins. lets say you have two flat surfaces you want to use these on... The bucket rivets/screws to the lower surface to create a recess where the pin is located (along with a spring) in which the bottom of the latch can enter when latched together. A second benefit of the buckets (with the spring), is that when you push the button in, it releases and the spring pushes the latch away
    Here it is with spring:
  17. #937
    Administrator
    Enterprise Alabama
    I made some some brackets to bridge between the sides and rear body panel and mounted the post on them. I threaded the brackets to make height adjustments easy.
  18. #938
    Freeport, ME
    A picture is worth a thousand words... a shot of the 1 inch angle across the rear fenders would be helpful too...
    Dan
  19. #939
    Huntsville, Al
    I didn't use the spring pockets either, although, I did get them...just one more piece that seemed to complicate the issue....I just did like wayne..height adjustment is accomplished in seconds.
  20. #940
    Administrator
    Enterprise Alabama
    Pic tomorrow
  21. #941
    south-central CT
    Buy them anodized and they will readily take primer. Or have them powder-coated and skip the anodizing.
    I know you said disappear, but they come in blue, black and red anodized. Might make for a nice accent since they will never really disappear. You can only get close to a spray paint color with powder-coat. Might be easier to match your body paint color to a powder-coat finished parts color.
    Thanks, Wayne for the Quik-Latch suggestion and pics.
  22. #942
    Administrator
    Enterprise Alabama
    Here is the bridge
  23. #943
    Senior Member Aloha818's Avatar
    Waikiki
    Wayne, Thanks for the info on the mini latches. Great idea. I want to eliminate the hoops pins on the back edge of the hood, and both sets on the engine cover, same buying a couple minis. I think I have a plan for the hood and the rear side of the engine cover. How did you eliminate the front pins on the engine cover on yours, if you don't mind me asking?
    "In wine there is wisdom, in beer there is strength, in water there is bacteria."
    818 (Chassis #34) Delivered 9/25/2013, First start 3/2/2014, First drive 4/5/2014, Registered 8/28/2015, First Dyno 3/18/2016, First SCCA event 4/3/2016, First car show HIN Honolulu 4/23/2016
  24. #944
    Administrator
    Enterprise Alabama
    Quote Originally Posted by Aloha818 View Post
    I do not think that I'll have to open the hood hardly ever so I made it a bolt on. I bonded plates on the hood and then made straps that attach in the nose opening and the back of the front wheel opening.
  25. #945
    Waikiki
    Thanks for the quick reply, but I'm referring to how you eliminated the hood pins on the forward end of the engine cover, just in front of the roll bar. In one of your pics I see a screw on the cabin side. I'm assuming you glassed in bracket and the screw keeps it in place?
  26. #946
    Freeport, ME
    I lke the mini latch "bridge" thanks for the photos. Can you show use where you placed the angle across the two sides?
    Dan
  27. #947
    Administrator
    Enterprise Alabama
    I bonded in a plate with a hood pin nut welded in on an angle so the pin would be normal to the area on the sides where the manual tells you to put the pin. then put the clip in from under the flat.
    I like the mini latch "bridge" thanks for the photos. Can you show use where you placed the angle across the two sides?
    I don't know which shot you want.
  28. #948
    Freeport, ME
    Any shot... I'd like to know where it works w/o interfering with something that I have to install later, like that would ever happen... I'm likely to put it where it interferes withe the trunk hinges (as an example)
    Dan
  29. #949
    Wayne, I know this has been a verrrrrrrrrrrrrrry long time , but which way did you bolt on the lower shock mount? Pointing towards the shock, the vertical brackets following the same line as the shock, or pointing towards the spindle?
    FFR manual shows both orientations, so we don't know which one is better, if there is one.
  30. #950
    Administrator
    Enterprise Alabama
  31. #951
    818 Junkie... bstuke's Avatar
    Atlanta, GA
    I need to remember to bring wheels. And spacers?
    818R For Sale!
    818R Sale Thread
    PADI Master Scuba Diver Trainer, PADI TecRec Gas Blender Instructor, Operations Manager - DNS Diving, Grand Cayman
  32. #952
    Administrator
    Enterprise Alabama
    Quote Originally Posted by bstuke View Post
    What wheels/offset did you get?
  33. #953
    Atlanta, GA
    17x8 +45, 18x9.5 +45
    818R For Sale!
    818R Sale Thread
  34. #954
    Atlanta, GA
    Kojin..
    818R For Sale!
    818R Sale Thread
  35. #955
    Edmonton, Alberta
    Hey Wayne, did you ever find the time to put your 818 on the dyno?
    818 SRX - #91
    Arrived 01/02/2014
  36. #956
    Administrator
    Enterprise Alabama
    Well not yet, my daughter got married last Saturday. So Thursday all the groomsmen went fishing...
    Thursday night someone broke into my shop and stole $2K worth of tools.
    But the wedding went off with out a hitch
    then Saturday night they came back and broke into the other shop and stole a 4 wheeler...
  37. #957
    Apr 2014
    Its someone you know. They knew when you would be gone and busy.
  38. #958
    Beautiful Bride and handsome groom. Best wishes to the new couple and joined families. Sorry to hear about your break in. Sounds like someone who knows you. I hope they get caught.
  39. #959
    San Diego Ca 92106
    Now how can you have a wedding and no one gets "hitched".
  40. #960
    south-central CT
    Perhaps you need to announce another outing and be lying in wait or at least have cameras set up? Sorry to hear of the loss, but congrats on the wedded daughter.
    Also, check pawn shops and Craig's list types of sites. "Friend" pawned a tool I lent him and said it was stolen from his car.
