Results 1 to 40 of 69
Thread: AJW Performance's Killer B Oil Pickup, Baffle, Oil Pans, Headers and MORE!
    Sep 2011
    Wareham + Bow
    Hello everyone! Here at AJW Performance some of our favorite Subaru parts are produced by Killer B! We've enjoyed their products for years and have them on all of our shop subarus and we want you folks with 818 builds to enjoy them as well! Their Oil Pickup is one of THE BEST on the market and is important when it comes to fixing the weak OEM oil pickup! Please see below for some of the products they offer!
    The Killer B Holy Headers:
    What can be expected from Killer B Holy Headers?
    · Improved throttle and Boost Response
    · Customers report +25wtq and +25whp on average
    · More Consistent EGTs across all cylinders
    · More Power Higher into the Rev range
    · Improved Fuel Efficiency
    · Perfect fit! (some WRX models may requite OEM Oil Cooler to be rotated)
    The Subaru Killer B ULTIMATE Oil Pickup!
    We have all heard the horror stories. You’re just driving down the road minding your own business and then boom your engine blows without warning.
    This ULTIMATE OIL PICKUP uses a .12” thick double bracket, 3X OEM oil pickup tube thickness and a brace between bracket and oil pickup tube to further strengthen the assembly. This is a super duty, engineered solution. No other vendor has anything this rugged available, although I’m sure it will be copied. You asked for it, so here it is. Fits all EJ25 motors
    The Subaru WRX/STi High Performance Baffle and Windage Tray:
    Features and Advantages of the Killer B Motorsport Windage Tray / Baffle over the OEM piece.
    • Closed rear section to prevent oil from sloshing into the crank under hard acceleration and aggressive shifts.
    • Block contoured profile to minimize oil returning from the heads interfering with the crank.
    • Directional louvers prevent oil in the pan from splash/sloshing into the crank.
    • Low profile design to control windage and strip oil from the crank immediately to reduce oil “roping” on the crank.
    • Improved oil entry to the pan/pickup to help prevent oil starvation.
    • Made from stainless steel for long life, durability and corrosion resistance.
    Features and Advantages of the Killer B Motorsport Windage Tray / Baffle over other aftermarket baffles.
    • Uses OEM baffle mounting locations
    • Not a sandwich between pan & block design that is difficult to install and more prone to leak.
    • No rubber parts that can sag and stay open after repeated heat cycling.
    • Not Holy Cow expensive!
    So what’s all this mean? It means more power due to the reduction in oil interfering with the rotation of the crank and allowing it to spin more freely. Unless it’s in the bearings, anytime oil comes in contact with the cranks or connecting rods it robs power. Reduction of oil splashing and beating off crank & connecting rods will also lower oil temperatures.
    Subaru WRX/STi EJ25 Optimal Oil Pan:
    Our V2 Performance Oil pan is designed to reliably meet the demands of high performance Subaru Engines used on street or track applications. Oil Pan holds an extra 1.4 quarts of oil, +30% increase in capacity over OEM. Optimal Oil Pan was designed to work with our Ultimate Oil Pickup (OEM ones are known to break), but can be modified to work with the OEM pickup.
    3D CAD Designed
    · 1/8” thick CNC Laser cut pan
    · CNC Formed
    · TIG Welded
    · (1) OEM Port & (1) 1/2” NPT Port (Plugs or Adapters Required
    · Comes with ALL Mounting Hardware
    · All Pans Fit and Leak Tested
    · No Moving Parts
    · Fits Most Headers
    · Over 30% Increase in Capacity
    · Streamlined Flow-Through Baffles
    · Powder Coat Finish Available
    · Retains OEM Dipstick
    Please visit Killer B's website for other awesome parts that we can provide you folks! Remember, please PM us for optimal pricing!
    http://www.killerbmotorsport.com/ind.../PartsList.htm
    Sep 2011
    Wareham + Bow
    Killer B parts are ready to be shipped!
    Sep 2011
    Wareham + Bow
    Killer B items are here and ready to ship out!
    Sep 2011
    Wareham + Bow
    We've got the best and lowest prices on Killer B parts! Please PM us for the lowest prices around!
    Brisbane, Australia
    I just placed and order for a pickup and windage tray, the price from AJW was excellent
    Kirkland, WA
    I already have my pickup and baffle, but might be tempted to buy the header !
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
    Clovis, Ca
    I had that header- But it would not fit YMMV. I do have a AJW motor though with all the internal goodies listed above
    Thanks- Chad
    Sep 2011
    Wareham + Bow
    Quote Originally Posted by DodgyTim View Post
    Thanks Tim!
    Chicago, IL
    Sorry Chad if you mentioned this in your build thread and I missed it, but could you say where the interference was with those headers? Got a pic (even better)?
    Thanks.
    -j
    Executive Director
    The Community Garage
    Jan 2012
    Surry Va
    I'd also like to know the issue with fit
    I'm ready to buy, glad I saw this first
    Sep 2011
    Wareham + Bow
    I can't confirm fitment for certain builds but if someone has all Killer B products, they should fit perfectly fine.
    Clovis, Ca
    This was my issue. YMMV- also note I have an AJW motor.
    http://thefactoryfiveforum.com/showt...ghlight=header
    Thanks- Chad
    Sep 2011
    Wareham + Bow
    Hello folks, don't mean to revive a thread from the dead but wanted to give some input to this Killer B header issue.
    So the Killer B header essentially fits all 02-05 WRX, and 04-07 STi. It should also fit all 08+ WRX, and STi but will NOT fit 06-07 WRX, LGT, and Forester XT this is because of the oil cooler, it is angled.
    Sorry that it took us so long to figure this whole issue out, but now that is is hopefully we can put it to rest!
    Here are some photos:
    Not noticable as much from the top, but at an angle...
    It is a noticeable change as opposed to this one...
    Here is a STRAIGHT Cooler:
    Please let us know if you have any questions!
    Sep 2011
    Wareham + Bow
    Hey folks, Killer B items are ready to be shipped to your door!
    Sep 2011
    Wareham + Bow
    A lot of Killer B items in stock and ready to ship!
    Sep 2011
    Wareham + Bow
    Killer B makes a quality product, have questions about fitment and options? PM us! We're here to help!
    Sep 2011
    Wareham + Bow
    Lots of Killer B items in stock!
    Apr 2014
    Killer B makes awesome stuff. Used a few of their parts on my v5 sti RA
    Sep 2011
    Wareham + Bow
    Quote Originally Posted by ruckus racing View Post
    We're huge fans and always will be! Tough to find really good quality products these days!
    Sep 2011
    Wareham + Bow
    We have a lot of Killer B items here, ready to go!
    Sep 2011
    Wareham + Bow
    Good afternoon folks! Bump!
    Sep 2011
    Wareham + Bow
    Good Morning everyone! We have lots of items in stock and ready to ship!
    Sep 2011
    Wareham + Bow
    Many items in stock this week! What can we get you?
    Sep 2011
    Wareham + Bow
    Killer B items in stock folks!
    Kirkland, WA
    Quote Originally Posted by AJW Performance View Post
    A dirt cheap stock flywheel for a 2002 2.0
    Tony Nadalin
    Sep 2011
    Wareham + Bow
    PM'd you sir
    Sep 2011
    Wareham + Bow
    Killer B parts in stock and ready to go!
    Sep 2011
    Wareham + Bow
    Lots of Killer B parts available, what can we get for your build today?
    Sep 2011
    Wareham + Bow
    Killer B parts are in stock, let us know what we can grab for you today!
    Sep 2011
    Wareham + Bow
    Lots of killer B parts ready to ship today!
    Sep 2011
    Wareham + Bow
    Lots of killer b items in stock!
    Sep 2011
    Wareham + Bow
    Hey folks, lots of Killer B parts for sale!
    Aug 2011
    Logan, UT
    As a note, the angled portion of the oil cooler can be removed simply without any extra parts.
    Sep 2011
    Wareham + Bow
    Killer B components are in stock!
    Sep 2011
    Wareham + Bow
    Killer B parts in stock and ready to ship!
    Sep 2011
    Wareham + Bow
    Killer B parts are big sellers! We keep lots of them here and we're ready to sell them!
    Sep 2011
    Wareham + Bow
    Killer B parts in stock and ready to ship out!
    Sep 2011
    Wareham + Bow
    Killer B parts in stock!!!
    Sep 2011
    Wareham + Bow
    Sep 2011
    Wareham + Bow
