Results 1 to 4 of 4
Thread: Ford Big Block For Sale
    Maryland
    Building a new FF Roadster? Want to build with a BIG Block? I have what you need! I have a Ford 390fe side oiler built up with aluminum Edelbrock Heads, intake and a Holly 650 double pump carb with MSD ignition (coil and rotor). Motor has never been in a car since it was built. The engine turns. Asking $4,500. Will post pics later.....
    Junior Member HolmanBoys's Avatar
    Coconut Creek, FL
    390fe side oiler
    MM330,
    Can you please clarify what you mean by the phrase above? Is this a side-oiler block that has been sleeved down, or is it a 390 block that has had oil system modifications?
    Lee
    Broken Arrow, OK
    I could see how you could sleeve down a side oiler block to a 4.05 390 bore, but why?
    I understand doing the oil mods needed to all FE's, but thats to a center-oiler block. I don't understand how you can modify a FE center-oiler block to be a side oiler, and they didn't make any 390 side-oilers that I'm aware of.
    Senior Member Raceral's Avatar
    Stoneville NC
    I think the reason he asked the question is because that what you said you had for sale... a 390 side oiler. Read your own add.
    Al Adkins
    Certified "Kool Aid" drinker
