I decided to start a thread on the K-tuned shifter I got from Wayne (Very Cool Parts).
I will be getting to mine soon eventually, and already have some questions.
Tom posted photos of his install here, and this helps to see how the tranny side goes together.
These help, and since I just pulled the Subie shift bracket off the back of my donor's tranny, I can start on that end of things. One question I have is: do the FFR cable washers get used with the shifter? If so, they seem to need trimming to fit the k-tuned shifter, if not, what washers are used? I'm not clear on how to assemble that end of it.
Wayne/Tom/Eric... I know all of you have used it successfully, but I'd really appreciate it if you chime in with any additional install tip and photos for us mere mortals. I figured a new thread makes more sense than PMs, so that it's documented here on the forum. The shifter is so cool, I have to believe a lot of builders will be putting it in!
Lee
