Folks,
How did you wire the fuel pump and gauge? I see there are 2 fuel senders, did you just short out the sub sender and wire the sender in the tank to the main sender wires if that makes sense. For the pump, just break out the wires from the connector and go to the pump? I am using the Boyd tank if that makes a difference.
Henry
