Results 1 to 15 of 15
Thread: Kill ABS light in cluster...How to?
    Houston
    I do vaguely remember reading something in a post. Used search, but cannot find what I need. So please...
    With all ABS and ABS controller removed my ABS light comes on. How can I put it to sleep?
    Quote Originally Posted by freds View Post
    Pin B3 going into the cluster gets pulled high to turn off the abs light.
    I suggest jumpering the red/white from pin C7 to pin B3.
    See attached
    Houston
    Many thanks Bob
    fred
    Houston
    Quote [I suggest jumpering the red/white from pin C7 to pin B3.
    See attached[/QUOTE]
    A further question Bob. Looking page WI 87, it appears that jumpering C7 to B3 provides (or substitutes) the feed thru that is normally provided by the LED light....which only goes to ABS control module B301 pin 22....but the ABS control module does not exist any longer. Am I missing something (distinctly possible!!!).
    Thanks again
    fred
    Exeter R.I
    The abs signal wire to cluster must be removed completely to turn the light off. Trace it back through the harness and remove it and the ground the follows it's path.There is a red wire ( signal wire, might be red and white. I will have to look it up ) with a black ground from the controller through the opposite side of the harness than the bulk of the controllers wires travel. I removed these along with all controller wires, the unit and sensor wires and I have no abs light on dash. So trace the wire you removed back, I bet the signal wire is still grounded or something silly.
    Near Denver Colorado
    I remove the LED in the cluster when the mileage was reset to 0. There is some code that needs to be in the right sequence to kill the light. It may be posible in the EEPROM code to do it but unsoldering it out was easier.
    Larry
    See attached
    Thanks again
    fred
    It is not a feed through the cluster. Think of the cluster as a inverse light bulb.
    Pin c7 is only ignition power to the cluster.
    ABS fault signal comes out of pin 22 of the ABS and into bin B3 of the cluster.
    Remove the Lg/Y wire between the cluster and ABS if you haven't already.
    12v on pin b3 will turn off the light.
    Ground or (not connected) on pin B3 will turn on the light.
    I hope this makes sense
    PS: They make that way as a safety feature. If the ABS fuse blows, the light comes on to warn the driver.
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    I read somewhere that the polarity of the ABS light signal changed. I think it was between 03 and 04. If connecting it high doesn't work, try ground.
    Larry
    Exeter R.I
    My setup was 02 so it is prob different for the later years. I believe you can tune it out also.
    Houston
    I really appreciate everyone's help, thanks
    fred
    Houston
    Quote Originally Posted by K3LAG View Post
    Larry
    Going high did not work...ground did! Thanks Larry. I have an 06 so you remembered correctly.
    Great help from you and Bob and everyone.
    fred
    You all may laugh at what I did but it worked. I just installed black silicone in where the led was and no more light. It is only cheating if you get caught. LOL.
    Exeter R.I
    Cool
    Feb 2013
    Bowling Green OHIO
    can the abs light be turned off using a cobb tuner?
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    Quote Originally Posted by dougkirkbride View Post
    No. The ECU is not involved in the ABS light in any way.
    Larry
