I am helping a friend build a 33 HotRod. We are using a fuel injected LS3 motor. I don't know what fuel pump and regulator I need. I would to use an in-tank pump, but I don't want cut my tank open to install it. So, My question is what is the best set-up for this system. Also, does the return line come from the regulator or the fuel rail.
Thanks for any help you guys can provide.
Larry
