Results 1 to 3 of 3
Thread: Be careful when comparing 02-03 wiring to later years
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    This is just a quick warning to those doing wire diets. Be careful of the connector numbers. The 02-03 diagrams use different numbers for the exact same connecters as compared to the later ones. For instance if you look at the instrument cluster section, the 02-03 manual has the connectors labeled A, B and C left to right. On the later ones, they are right to left. Another example is the two connectors on the Integrated Unit, B280 and B281. On the earlier ones the 16 pin connector is B281 and the 20 pin connector is B280. On the later ones, the connectors are labeled just the opposite.
    There may be other examples, but these are two I noticed.
    Larry
    Mar 2014
    Edwardsville, IL
    Thanks for the heads up. I am about to start the wire diet on my 02 donor.
    Exeter R.I
    This is because the actually cluster and unit there mounted oppositely.
