Likes Likes:  2
Page 4 of 27 FirstFirst ... 2345614 ... LastLast
Results 121 to 160 of 1079
Thread: MRG MotorSports 818S Build
  1. #121
    Spent both days this weekend autocrossing in my original donor.
    My Impreza looks huge compared to the two Miatas. I need to get done with the 818s.
    San Jose, CA
    I've just caught up reading your whole build thread and I'm definitely going to do my best to end up a with a similar setup for the wiring. VERY nice job.
  3. #123
    axle puzzle day
    organized my axles to figure out what I had to work with.
    All eight of my outer cv joints are installed in the cars.
    Starting left to right.
    Two 06 impreza rear axles with inner joints (not needed)
    Two 04 forester rear axles with inner joints (not needed)
    Four FFR axles (needed)
    Two 04 forester front axles (not needed)
    Two 04 forester front tripod inner CV joints (needed)
    I believe these are aftermarket at they are not Subaru green.
    The spline on the tripod does fit the FFR axles.
    Two 06 impreza front tripod inner CV joints (needed)
    Two 06 impreza front axles (not needed)
    Now to start reassembling with the FFR axles.
  5. #125
    Mounted the rear suspension today. I used all adjustable arms (5 per wheel). Does anybody have the center to center distance for each of the links?
  6. #126
    Huntsville, Al
    I don't know about a belly pan, but don't forget to install a parking brake
  7. #127
    QC, Canada
    Besides the repair costs and the people who forgot to tie the car on platform (ebrake is one thing but it needs more), there looks to be a hump on the belly pan between the 2 front wheels. What's its use?
    Tracked May 27/July 26, 2017
    Build Completed Winter 2021
  8. #128
    Apr 2014
    skid plate. its lower there because the car needs the clearance. When jumping the rally car at speed, it does slam the ground.
  9. #129
    QC, Canada
    Oh yeah that's true, I forgot about that. Useless on my 818.
  10. #130
    Apr 2014
    If you do decide to jump the 818, Please take video.
  11. #131
    Working on fuel pumps
    As I am designing a front mounted fuel tank. I am considering using the OEM fuel pump assembly.
    I have two donor pumps.
    The one on the left is out of a 06 NA 2.5 impreza.
    The one on the right is out of a 04 forester XT 2.5 turbo.
    Here is a comparison:
    Length is same, perfect for 11" deep tank.
    Fuel filter sock. Bigger on turbo
    Fuel pump: same physical size
    Fuel Temperature sensor: same
    Fuel level sensor: slightly different
    Fuel filter: NA in tank Turbo on firewall
    Fuel Pressure regulator: NA in tank Turbo on engine
    Fuel Return Line: NA none Turbo yes
    Pressure damper: NA near engine Turbo in tank
    Electrical connector: same
    I'm going to use the turbo version in my tank with an new Aeromotive 340 Stealth pump.
  12. #132
    Aug 2013
    Weird, my 05 fxt had one that looks like the one on the left. Installed a walbro 460L incorrectly, needs higher guage wire, I'll snap a pic when I fix it.
  13. #133
    Quote Originally Posted by icky View Post
    Interesting: looks like Subaru bounced around on fuel supply configurations.
    Edit: I would like to see a picture of an 05-07 turbo pump, filter combo.
  14. #134
    Member Westview's Avatar
    Jan 2013
    Columbia, Maryland
    Here's the one that came with my Donor pallet from Wayne (Should be out of a 2006 WRX Wagon):
  15. #135
    Quote Originally Posted by Westview View Post
    Thanks Westview,
    That looks like the filter sock out of my 04 FXT. Do you know it the 06 wrx filter was in the tank or on the firewall?
    Jan 2013
    Columbia, Maryland
    Thanks Westview,
    I can't say for sure, but I think they switched to the in-tank filter by 06.
  17. #137
    Freeport, ME
    My 05 had the in tank filter, I bought an 02 filter from NAPA and mounted it to the frame...
    Dan
  18. #138
    A friend of mine spotted an 818 on "US421 The Snake" last weekend. Any one know who it was?
    The Snake . . . " 33 miles 489 curves 3 mountains 1 valley . . . from Mountain City, TN to Bristol, TN
  19. #139
    Jul 2012
    Encinitas, CA
    Probably the guy who bought Erik's!
  20. #140
    Firewall isntalled
    Had some time this weekend to work on the blue ICE car .
    Installed front firewall and tighten up most of the front suspension.
    Also installed the pedal box.
    Added a 2 x2 x 1/8" 16" long to mount the gas pedal. See pictures
    Richmond, VA
    Hey Bob, I just mocked up my suspension just like yours and was told my upper a-arm bushings were upside down. That the grease fittings point up instead of down. I think there are conflicting photos in the manual. I'm not sure, just passing on what I was told.
    Also, my ball joints sit in flat sockets, yours are tilted. Any idea why the differences?
    Travis
  22. #142
    Quote Originally Posted by thall818 View Post
    Travis
    Hi Travis
    Thanks for your comments.
    The grease fitting work either way. I think it is personal preference on the easiest way to get to them once the fenders are on.
    The earlier kits came with the angled "A" arms. I would rather have the straight ones.
    Fuel Line Question
    I am using some Teflon Braided Stainless Steel fuel line.
    http://www.summitracing.com/parts/sum-220985
    I have found some quick connect fitting to connect it to the engines fuel feed line.
    http://www.summitracing.com/parts/rus-644113
    http://www.summitracing.com/parts/sum-220141
    My problem is the return line. The engine has a 5/16 tube with a bulge in it. What is the proper way to adapt my hose to the Subaru tube?
    Front Gas Tank Installation
    Getting ready for the Front gas Tank Installation. Removed bottom bars to be replaced by bolt in bars and steel intrusion plate.
    All brake and clutch lines run inside the cockpit.
    Covered Fire wall with some Dynamat.
    Filled gas tank with some safety foam.
    Lengthen Subaru fuel pump bracket and wires.
    Used tubular sending unit.
    Mounted tank in Car.
    14 gallons total, Maybe 13 usable.
    Fuel lines tomorrow.
  25. #145
    QC, Canada
    Very very nice.
    Is that foam made just for that tank or it can go in the FFR tank? Actually, I think I don't understand its safety feature, if you haven't yet, maybe you can explain?
  26. #146
    Very very nice.
    See link:
    http://www.summitracing.com/parts/rci-7050a/overview/
    "safety foam reduces fuel slosh and helps to suppress explosions."
    Cannot use with gas level sending unit that have a float on the end of an arm.
    Has anybody else considered a rear mounted radiator?
    Freeport, ME
    yes, but I don't think airflow is enough with current configuration. I think you could do a rear mounted IC...
    to do it you would need to do some big time airflow work
    Dan
  29. #149
    I need to talk to one on my aerodynamic engineer friends. I would think rear vacuum should be as strong as front ram air.
    I do plan on opening up the side vents to ram the air into the engine bay. All that air will have to go out through the rear radiator.
    With side vent ram air and rear vacuum, it might be better than the radiator in front.
  30. #150
    QC, Canada
    Do we know any production car using such a design?
  31. #151
    Mar 2014
    Vacaville, CA
    80's 911?
  32. #152
    Rear Mounted Radiator install
    I temporarily mounted my rear radiator. It will move forward 6" after I shorten my transmission.
    Oh yea, the fans work running backwards.
  33. #153
    Mar 2014
    Vacaville, CA
    Very slick.
  34. #154
    I also moved my expansion tank on top of the frame rail. I'm thinking the higher the better.
  35. #155
    Mar 2014
    Vacaville, CA
    Are you still planning on going with a front fuel tank? Any thoughts as to the design?
  36. #156
    Freeport, ME
    Are you going to open up the side vents fully vs. using the smallish cuts supported by the FFR vent screens and trim? Moving the IC too?
    Dan
  37. #157
    Exeter R.I
    I like the idea, but this seems like it will get hot air vented to it without direct ducting (the turbo and exhaust should be fully insulated). I would think the heat soak potential would be very great. I am interested it what else you add to this setup to make it effective. Definitely outside the box thinking, and hopefully it can yield a postive result.
  38. #158
    Quote Originally Posted by Boog View Post
    Not planning any more, Check out post 145 above.
  39. #159
    I will be opening up the side vents fully and then some. Maybe something like this:
    Also going to a AWIC. I have not decided on location of heat exchanger.
    Hey Metalmaker,
    I do plan on fully insulating the exhaust the best I can.
    I think you are talking about heat soaking the main radiator. I plan on bringing as much air as possible into the engine compartment. Enlarged side vents and possibly opening up the side pods right behind the front wheels.
    Metal, you are the main reason I went this direction. An engine under high load forms little bubbles, like the bottom of a pot about to boil. These bubbles all collect together some where and form an air lock in the cooling system. I think this is what happened to your engine. Possible in the top of your heads or in the front radiator. Were your blown head gaskets at the top of the engine?
    As far as heat soaking the IC. I will be going to AWIC.
    Thinking outside the box has been my career. I have fallen on my face many times. Note to self: Learn from my mistakes.
