10
65
View Poll Results: How to finish the mesh panels?
- Voters
- 57. You may not vote on this poll
Gloss Black
Unfinished Aluminum
also...
Since my donor was more rust than car I have a lot of hardware I need to replace. Finding the names/part numbers has been a bit challenging, so here are guides for the front and rear suspension including diagrams, part numbers and the numbers of each I estimate are needed based on the 818 assembly manual.
front suspension:
http://1drv.ms/1oCij8V
rear suspension:
http://1drv.ms/1mJmkeE
