Page 1 of 3 123 LastLast
Results 1 to 40 of 83
Thread: Watch ADD guy build car
    Member Westview's Avatar
    Jan 2013
    Columbia, Maryland
    I'm a little late starting a build thread, but procrastination is an integral part of my personality.
    My donor is a 2006 WRX Wagon, which I purchased from Wayne at Very Cool Parts. Here are some pictures picking it up down in Alabama:
    Getting it out of the bed of my truck once I got home:
    Picked my kit up a few weeks ago:
    I have a lot of back ordered parts. I missing the entire Box 6 which is the bulk of the aluminum. No gas tank, no headlights, missing exhaust hardware and more. I don't think any of that will be a problem for quite awhile.
    I spent this past weekend tearing my steering rack apart to "de-power" it. I post some picture of that soon.
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    Good to see you're getting started. Dave and I are just a few miles away if you need help with anything.
    Since we are several months ahead of you, hopefully we'll solve all the problems before you get to them!
    Larry
    Mechie3's Avatar
    You could always ask for a credit for the headlights and go aftermarket. I have the factory ones lying around too but think it would cost as much to ship them as you could buy them on ebay with free shipping.
    Zero Decibel Motorsports
    Fort Lauderdale Fl.
    Welcome and congrats.... Nothing wrong with procrastination!!!
    FFR Daytona Type 65 Coupe
    67 427 Cobra
    57' Belair
    34 5 window coupe Ford
    2003 Mustang GT
    99' ZX9
    85 Goldwing
    San Jose, CA
    Congrats and looking forward to following along.
    Leesburg, VA
    Hey man, I'm also about an hour away and pretty much at the same stage as you. I too was working on the steering rack this past weekend. Great so see we have a few builders in the DC area!
    Jan 2013
    Columbia, Maryland
    Quote Originally Posted by K3LAG View Post
    I certainly hope so...I don't want to have to solve all these problems!
    Given my penchant for procrastination, they'll probably be here before I make up my mind which way I want to go.
    Quote Originally Posted by riptide motorsport View Post
    Thanks! I appreciate the moral support. I'm just a little concerned that procrastination isn't the best personality trait for building a car.
    Quote Originally Posted by svanlare View Post
    Maybe we'll get to meet up at some point. Wait til you see the high tech tool I made to get my steering rack apart. I may be banned from the forum after they see that.
    Senior Member metros's Avatar
    NoVA
    Well don't leave us hanging. Post your high tech home made tool!
    <---Also local to you.
    Jan 2013
    Columbia, Maryland
    De-powering my steering rack
    Bolted my steering rack to a 2x4 in order to hold it down while I worked on it:
    First significant problem was the requirement to remove the 'plug' which holds the valve assembly in:
    My high tech solution to this special tool requirement involves a 2x4 and four 20d nails.
    First made a pattern to get the spacing down:
    Drilled a 3/4 inch hole in the 2x4 to fit over the shaft:
    Measured, cut and ground down the nails to fit the holes in the 'plug':
    Installed the nails into the 2x4:
    Placed my newly constructed, high precision tool on the 'plug' and tapped it with a hammer to remove the 'plug':
    Jan 2013
    Columbia, Maryland
    De-powering my steering rack (continued)
    Now I have the 'plug' out, just pull the pinion & valve assembly out by hand:
    Once the valve assembly was out I removed the 'Holder' and pressed the shaft out of the housing:
    Once the shaft was out, I used an angle grinder to cut the seal, and then a chisel to break it and remove it:
    That's as far as I got with the steering rack. Next I'm going to weld the valve assembly & pinion to fuse them together and remove the slop in the steering.
    Senior Member AZPete's Avatar
    Your high-tech tool looks good to me. Be sure to sign up as a vendor before you start selling it!
    Jan 2013
    Columbia, Maryland
    I hadn't thought of that...with material costs of about 25 cents I should be able to make nice profit!
    Jan 2013
    Columbia, Maryland
    Cleaning Steering Rack Housing
    Spent some quality time with a wire bush and my steering rack housing.
    Before:
    After:
    Now I'm down to tooth picks trying to get the remaining crevices cleaned out. An interesting internal conflict is brewing. My OCD will have me cleaning this thing for days. On the other hand my patients are wearing thin and of course my ADD wants to go work on something else for awhile.
    Freeport, ME
    looking good... I made my spanner out of scrap aluminum and a couple roll pins from ACE. I like that you invested 1/2 as much as I did!
    None of use has much patience...
    Nice tractor!
    Dan
    Freeport, ME
    Nice tractor Wayne!
    Dan
    Jan 2013
    Columbia, Maryland
    Spent some more quality time with a wire brush today. Cleaned up the tube nuts from the steering rack. I'm going to have the holes welded shut to seal up the rack.
    Before:
    After:
    Jan 2013
    Columbia, Maryland
    Did a little painting today.
    After doing some research I decided to use Eastwood Rust Encapsulator and Extreme Chassis Black to paint some of the parts on my build. I've laid down plenty of latex in my life, but have no experience with this sort of paint. My plan was to use a foam brush to paint my parts. That was a mistake. I was not prepared for how fast this paint dries. Brushing is not really an option. I could not lay it down smoothly even though its fairly thin. I had never used a spray gun before. My only spray experience involved aerosol cans. But I happened to buy a very cheap spray gun awhile back but never used it. So I decide it was time to try it out. It worked great and I looking forward to using it to finish things up. Here's a picture of my drying rack, which consists of to horses, two 2x4 and some closet hangers, its a little low to the ground but got the job done:
    Jan 2013
    Columbia, Maryland
    De-Powering the steering rack
    Finished up the steering rack. I had the pinion gear welded to eliminate any movement. I copied the approach Rasmus took, welding through the holes in the valve:
    One word of warning if you take this approach, make sure you clean up the weld splatter. I missed some, put my rack back together and it made about half a rotation before it hard stopped. Had to take it all back apart and discovered weld splatter sticking out had caught on one of the power steering fluid orifices inside the housing.
    Here it is all back together:
    Jan 2013
    Columbia, Maryland
    Axle/CV Joints
    Pulled apart my donor axles/CV joint today. This is what I started with:
    Don't have a vise, so I clamped the Axle between two 2X4s to hold it while I tapped the CV housing off with a hammer:
    It's a messy job:
    Here's everything apart:
    Here's a the inside of the front inner CV joint housing. There doesn't seem to be any scratches, but I was surprised by how they look. They look like they are burned:
    Still have some work to do taking apart the rear outer CV joint and clean it up. Then it will be time to put the CV joints on the Factory Five supplied axles.
    Jan 2013
    Columbia, Maryland
    Installed my first aluminum panels on the front firewall:
    Jan 2013
    Columbia, Maryland
    Front Firewall
    Finally finished the front firewall:
    I have a few holes to fill in. Some made by Factory Five for shipping purpose and a couple of mistakes I made:
    San Jose, CA
    Looks great, feels good to check off as if feels like something real is done.
    Looks good. The only error I notice is calling extra holes mistakes whereas they are actually "weight saving voids". I've added some WSVs to my build also.
    Senior Member Rasmus's Avatar
    Las Vegas, USA
    I using that. It's not a mistake; it's a WSV.
    my Motto: If you can't fix it, feature it.
    Jan 2013
    Columbia, Maryland
    LOL, now that's funny!
    Jan 2013
    Columbia, Maryland
    Front Lower Control Arm Ball Joints
    I didn't like the looks of my ball joints so I got new ones
    The first one I removed simply fell out and came apart when I removed the nut
    The second one came out of the control arm easily, but the cone would not come off the ball joint spindle. I cut away the rubber and was able to get a puller on it and pull it off:
    Here's the new one next to an old one:
    Jan 2013
    Columbia, Maryland
    Fuel Tank Finally Arrived
    My fuel tank finally arrived today:
    Jan 2012
    Surry Va
    You get my vote for best use of 2x4s in a build
    Looking good
    Jan 2013
    Columbia, Maryland
    Quote Originally Posted by gwarden View Post
    Looking good
    Thanks!! It's such an honor to be nominated for Best in 2X4
    Jan 2013
    Columbia, Maryland
    Installed the front lower control arms today. I had to drill a hole in the driver's side firewall to get the control arm to fit. Found a button plug at Ace Hardware to plug the hole from the inside. The plug just barely fits over the end of the bolt that is sticking through the firewall:
    Yup, I did the same. If the hole is big enough for your 19mm socket you can torque the nut later when you've got wheels and it's at ride height.
    Freeport, ME
    the "wiggle" on the rear bushing is supposed to be on the bottom...
    Dan
    Jan 2013
    Columbia, Maryland
    Wow...Thanks for pointing that out!!! I completely missed it. I turned it around and now the hole I drilled in the firewall is off
    Jan 2013
    Columbia, Maryland
    Here's my now miss-aligned firewall hole for the driver side front lower control arm:
    So I drilled 1 inch hole. Had to flip the bearing which moved the bolt off center. I originally figured I needed at least 1 ⅛ inch hole to fit a socket through. So I was always planning to enlarge the hole. Now the center of the bolt is .818 inches from the far edge of the hole I drilled. If I split the required 1 ⅛ inches in half that gives me 9/16ths or 0.5625 inches. If I add the 0.5625 inches to the 0.818 inches that gives me 1.3805 inches. This is approximately 1 ⅜ inches (1.375 inches). To be safe I think I need a 1 ½ inch hole in order to fully encompass the existing hole and leave enough room for a socket. Finding a plug to fit a 1 ½ inch hole is proving to be a bit of a challenge. It seems once you get over an inch the recessed portion of the plugs are reversed. So it would have to be installed from same side of the fire wall as the LCA. Which means I would have squeeze it behind the LCA bolt to install it. So far the best plug I've found is this one:
    It's for a 2 inch hole and I would rather not go that large if I can avoid it. It also looks pretty thick, so squeezing it behind the LCA bolt could be challenging.
    While I've been pondering that dilemma, I did press the front hubs out of their housing:
    Now all I have to do is figure out how to get the bearings off the hub. I may have to let someone else do that for me. I know there's a special tool to do that and I can't think of anyway to do it without the special tool.
    Exeter R.I
    Press out from back side out the front where the snap ring is. It's easy with a press and something that fits on the race. Soak with pbblast, but from the looks of it that should come right out . With the bearing on hub, put in a vise and get long a pry baror slide hammer etc
    Jan 2013
    Columbia, Maryland
    Front Hubs/Bearings
    I tried to pry the bearings off the hub with no luck. So I ended up buying a bearing splitter/puller from Harbor Freight. It just barely fit on the hub, but I got it on and was able to pull the bearings off:
    I removed the bearings from the housings and found marks on the bearing surfaces of the housings:
    I'm not sure what to do about these marks. I could use some advice on this one. I can't feel the marks when I run my finger over them. I don't want to damage the surface trying to remove the marks, but I'm concerned that not removing them may result in premature bearing failure.
    You're correct that a 1.5" hole is good for the front lower control arm bolt. Look in Ace Hardware for a 1.5" metal hole plug like this.
    If your local Ace doesn't have these, PM me and I'll get a couple from my Ace and send to you. These can be placed from the other side (the inside of the firewall).
    Leesburg, VA
    I'm not sure what to do about these marks. I could use some advice on this one. I can't feel the marks when I run my finger over them. I don't want to damage the surface trying to remove the marks, but I'm concerned that not removing them may result in premature bearing failure.[/QUOTE]
    Those marks are on the inner race surface of the bearing, which also has to be pressed out of the hub. The new bearings will come with the two bearings and the race. I'm also in the middle of replacing my bearings - I've got all 4 spindles disassembled and painted and new bearings are in. I just have to pack them with redline synthetic grease and press them back into the spindles. I found a pretty good video on youtube for replacing subaru wheel bearings that helped out a lot.
    Jan 2013
    Columbia, Maryland
    STiWRD, Thanks! You are absolutely correct. I figured it out about an hour before I read your post
