Hello All,
Gauging interest for the body brace I made for my own 818. This part attaches to both sides of the rear side panels to provide initial adjustment and long term stability. I had lots of trouble getting my side panel to engine cover gaps consistent until I put this on my car. The ends have opposite threads so that by turning the center shaft you can pull in or push out the rear fenders. On my car the two bolts that hold the fiberglass to the shock tower brace started to spiderweb crack due to the amount of stress put into that area. This brace helps to spread the side/side load out over multiple points that are spaced farther apart than 2".
Cost with steel rod ends: $58 + shipping
Cost with stainless steel rode ends: $68 + shipping
Both sets use full stainless hardware for all nuts and bolts. Triangular piece is laser cut and tumbled aluminum.
If there is enough interest I'll place an order for parts.
Pictures from my build thread.
