Well, the AWIC setup isn't cutting it for my purposes. I need something that handle multiple ~20 minute track sessions in 90+ degree days. As is, I would need to replace the water in the system between sessions. This would be fine for occasion use or drag racing purposes. As of now, the parts are still installed, but they'll be removed this weekend. Everything is setup to bolt onto an 818. The only thing you'll need is some 3/4" hose and a blowoff valve.
Kit includes:
- Type 3 air-to-water intercooler core (drilled/tapped for 3/8 NPT temp sensor on hot side and 1/8 npt temp sensor on cold side) (has welded brackets for mounting to transmission)
- Type 118 heat exchanger/radiator w/ 7" fan
- reservoir ice box
- remove filler cap
- Numerous brass fittings
- Custom intercooler pipes (has fitting for 3/8 npt temp sensor and Tial/TurboSmart 50mm blowoff valve - not included)
- water pump (Bosch or Meziere WP136S)
Here are some pictures of it installed. I'll have more pictures after I remove it this weekend.
$500 shipped w/ Bosch pump
$600 shipped w/ Meziere pump
+ $150 for TurboSmart Race Port BOV
Please contact me directly at [email protected]
