Results 1 to 12 of 12
Thread: Modular Coupe First Start
    Member Tim Potts's Avatar
    Pa
    Just click the pics for video
    Not that bad I quess once the lifters all pumped up and in particular cylinder #5
    The more it ran the smoother it got.
    looks good after a screen refresh
    FFR#2496
    FFR#CP373
    Fort Lauderdale Fl.
    Sounds sweeet, congratulations!
    FFR Daytona Type 65 Coupe
    67 427 Cobra
    57' Belair
    34 5 window coupe Ford
    2003 Mustang GT
    99' ZX9
    85 Goldwing
    Tim,
    Way to go! That is quite an install. Well done and sounds great!
    Junior Member Matt's's Avatar
    Hello Tim,
    I had been told by some of the FFR guys that the mod motors won't fit under the Coupe hood? What did you have to do to make it work? I was also wondering what the headers you were using are, and do you just plan to leave them open exit behind the wheel?
    Thanks for your time!
    Pa
    Footbox Mods and Roadster exhaust
    Matt, No problem with hood clearance. The only real problem with putting a Modular in the coupe is the width and the headers. I solved these two issues with modifications to the footboxes and FFR Roadster headers and Roadster sidepipes.
    FFR#2496
    FFR#CP373
    That's good to know! What did you have to modify in the footbox area? I'm pretty tall so cant really afford to loose any legroom.
    Thanks again Tim!
    What was I going to say?
    Pa
    Matt, For the driver side all you need is 2 pieces of FactoryFive Aluminum FFR#14718 LH 4.6L INNER WALL and FFR#14719 4.6L INNER WALL TOP.
    So the Pass side was the only side I really had to modify and in doing so I also dropped the floor. So while cramping up the foot space in favor of the motor nothing was done that effected length other than increasing it by dropping the pass side floor.
    One more thing you will need is a new shallower oil pan, and I would recommend the Champ pan sold by Richard Oben of NorthRacecars.
    FFR#2496
    FFR#CP373
    Nice, so the driver's side foot area isn't effected at all?
    Houston, Texas
    When you say 4.6 will fit under the hood, is that only the 4 valve engine? or will the 2 valve 4.6 fit as well?
    Pa
    Quote Originally Posted by Riff View Post
    Yes. Same mods for the 2V and height is a non issue.
    FFR#2496
    FFR#CP373
    Senior Member bil1024's Avatar
    NY
    Tim, PM sent with questions
    MKIII #5835 Someday I Suppose's Avatar
    Stanhope, NJ
    Tim, congrats, gotta love first starts without pipes :-)
    MKIII #3835 IRS, Anderson Performance 408 Levy T-5 Trans, Team III Wheels
    Paint completed November 2010, passed NJ State Safety Inspection June 21st, Tagged and First Drive 7/1/2011
