Page 12 of 54 FirstFirst ... 2101112131422 ... LastLast
Results 441 to 480 of 2134
Thread: Plavan's 818R Build Thread
  1. #441
    Senior Member Brando's Avatar
    Irvine, Ca
    I also have a light ACT flywheel. I have continually suffered from stalling. I thought it was a vacuum leak but turns out it wasn't. I told the guys who tuned it, the told me why and said they fixed it on the tune. Not so much.
    I still haven't been able to figure it out, i was tempted to move the idle needle on the intake.
    I have been blip-ping the throttle while braking until its solved...gets old fast
    Your engine sounds epic
  2. #442
    Exeter R.I
    Mine never did this, but I have an oem flywheel.
  3. #443
    Congrats on the first drive! I hope to be driving mine very soon as well. I also have an ACT streetlite, so I'll let you know if I have any issues.
  4. #444
    Mechie3's Avatar
    Subaru calls it the IACV.
    I've had various reasons for stalling my subaru:
    Too low idle (with LW FW and LW pulley)
    leaky head gasket (logging showed it going lean coming to a stop then smoothing out)
    bad 02 sensor
    Changing the IACV gasket is cheapest and easiest first fix.
    Zero Decibel Motorsports
  5. #445
    Clovis, Ca
    Thanks! I took it out for a few more laps later. Breaking stuff in sucks when you want to floor it.
    Brando- How long did it take to get the Wilwoods broken in? It's taking alot longer than I'm use to. My pedal is super firm, but braking sucks right now (new pads and rotors). I'm probably at least going to go with the ST43 Raybestos race compound. I'm not sure about these pads right now.
    Thanks- Chad
  6. #446
    Clovis, Ca
    bad 02 sensor
    I thought Drive by wire car did not have a IACV?
    Thanks- Chad
  7. #447
    Mechie3's Avatar
    That's correct. Forgot you had an 06 motor. I was responding more to others not knowing what Subaru called their control valve. The DBW just controls the throttle plate directly.
    If you can datalog it that can help determine if it's going rich and stalling or lean and then go from there. Compression check would be easy in the 818 too since the spark plugs are readily accessible.
  8. #448
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    Mechie, how did a leaky head gasket cause this and how would coming to a stop change it? I ask because I'm trying to solve a lean condition myself.
  9. #449
    Clovis, Ca
    I do not think there is any head gasket issue. Its a brand spanking new motor. I just think I need to bump the idle RPM or injector cutoff values.
    Thanks- Chad
  10. #450
    Mechie3's Avatar
    In my case (not a new motor) there was a small air leak that was mostly noticeable at lower rpms/air flow. At higher rpms/airflow the amount of the leak was small relative to the rest of the airflow. I upped the idle rpm to get by for a while but eventually my coolant was all brown so I took it apart and put new gaskets on and it was fine.
  11. #451
    Irvine, Ca
    I drove the car around the street for 100 miles, ran 1 day of autocross, then when I went to streets of willow I was finally able to lock up my R6's. Seems excessively long but that was how it was for me. Even then I had to plow into the brake pretty hard to get it to lock.
  12. #452
    Hindsight's Avatar
    Atlanta
    Ahhhhhhh! Ok that makes perfect sense. Do you think this kind of leak would show up on a compression test, or would have to be a leakdown test?
    (Sorry to hijack your thread Chad.... I've been chasing this problem down for a year now!) I would think to solve your issue, you could use an AccessPort or whatever to up your idle RPMs, like you mention, to compensate for the lack of inertia in the flywheel.
  13. #453
    did you check for vacuum leaks yet?
  14. #454
    Clovis, Ca
    I gave it a good look. No idle problems at all. When its cold, it idles higher, then as it warms up it gets down to around 750 RPM. No jumping or anything.
    I just think my lightweight pulley and Flywheel are the cause. I'll bumped up the "warm" RPM's to 900 to see if that will help catch it. I may go a little higher if that does not help.
    Thanks- Chad
  15. #455
    Senior Member waruaki's Avatar
    Salem, Oregon
    I run the lightened pulley's but not the flywheel. I have yet to have it ever stall on me.
  16. #456
    iWire's Avatar
    Lake Forest, CA
    Quick test to see if the stalling is from a vacuum leak (stalling when coming to a stop is a common symptom) is just to unplug the MAF. It'll run off the MAP sensor and if it doesn't stall you know it's a vacuum leak, if it does it's not.
    When we say to our customers "if there is anything you need, please ask," we mean it.
    iWire Subaru Wiring Services
    Over 100 Custom 818 Wiring Harnesses Built
    http://www.iwireservices.com/factory...18-wiring-kits
    [email protected]
  17. #457
    Clovis, Ca
    Quote Originally Posted by iWire View Post
    I started it up, pulled off the MAF and it stalled.
    Thanks- Chad
  18. #458
    Suisun City, CA
    That's only if you're running a MAF based tune, correct? I'm running Speed Density.
    818S - #67 (SOLD IT!)
    Delivered: 18 November 2013
    Go Karted: 29 December 2013
    Finished: NEVER!
  19. #459
    Clovis, Ca
    FYI- I'm ditching the digital display. You cant see it in direct sunlight light. I worried about that. No Roof= No Good for display. Just going VDO gauges and using my Traqmate from the other race car. The Traqdash is better in sunlight than a tablet.
    Thanks- Chad
  20. #460
    Clovis, Ca
    In preparation for the dry sump pump/kit, I had to install the A/C idler pulley and associated bits. I had to swap out the steel alternator bracket (Everson Alternator turnbuckle kit) to the original bracket. The turnbuckle Alt belt adjustment still works which is nice. The dry sump pump mounts where the A/C compressor was.
    Thanks- Chad
  21. #461
    Clovis, Ca
    I Plastidip'd the front of the dash. I'm pretty happy with the results. It breaks it up nicely from the top, and gives it a suede type look/feel. Crappy cell phone pics.
    Thanks- Chad
  22. #462
    Hindsight's Avatar
    Atlanta
    Nice! I would have never thought to use plasti dip. I ordered my 818 with a "padded dash", which I was told was a new option, but they couldn't tell me where the padding is so I am assuming top only. I may do as you did for the front if that's the case.
  23. #463
    Yeah, get a better cell phone, Chad.
    I will use plastidip as well on a couple of parts, so it did adhere nicely on the dash? How many coats?
  24. #464
    Clovis, Ca
    The pictures don't do it justice. You can see the shadow of my hands taking the picture on the dashpod picture. In real life its nice and uniform.
    Thanks- Chad
  25. #465
    Suisun City, CA
    Nice. I'm actually thinking of doing the opposite on mine (doing plastidip on the top and a semi-gloss or full gloss on the front).
    Finished: NEVER!
  26. #466
    Clovis, Ca
    Quote Originally Posted by JeromeS13 View Post
    I was going to do the top in a carbon fiber wrap..... but I was missing 3" of wrap to cover the whole thing in one piece..... Murphy's law!
    Thanks- Chad
  27. #467
    Houston
    I have a light weight flywheel and crank pulley. I upped the idle speeds across the board with RomRaider and ECUflash. It helped a bunch, but it is still "iffy" and I get occasional stalls.
    I have no air leaks etc. (from pressure tests of the inlet tract.). So I'm going to change to stock flywheel and damped crank pulley. Rapid engine accel. is not as important to me as not worrying about some heel and toe to avoid stalling.
  28. #468
    Clovis, Ca
    Quote Originally Posted by freds View Post
    Thanks- Just curious what Idle RPMs you set.
    Thanks- Chad
  29. #469
    San Diego Ca 92106
    Plasti dip has a kit for faux carbon fiber.
    http://www.youtube.com/watch?v=7N5N-AYaENI
  30. #470
    Houston
    There are Three Idle Speed Target maps A, B, and C. The attached picture of the originals on my 06 with DBW.
    I have no idea which one the ECU is programmed to use under which (?) circumstances.
    So I increased each and every one by 200.
    Since I only have a running go-kart and cannot really drive it around and gauge the difference, I cannot comment with any good facts. However it did make it significantly better on my neighborhood "closed circuit".
    But it still is inclined to stall like when goosing it as I reverse up my driveway, and have to let up precipitously.
  31. #471
    Orange, CA, USA
    I wonder if plastidip would be a good alternative to the typical suede wrap to reduce glare and reflecting in the windshield.
  32. #472
    Clovis, Ca
    Quote Originally Posted by Evan78 View Post
    I think it would be great.
    Here is a better picture in the car. Disregard the fiberglass fingerprints from drilling
    Thanks- Chad
  33. #473
    Irvine, Ca
    For your drysump, are you going to use your exhaust, the oil pump, or a vacuum pump to pull the air out of the bottom end effectively?
  34. #474
    Clovis, Ca
    The Element Dry Sump kit includes a scavenge pump that attached to the A/C bracket. It also utilizes the A/C idler pulley for the belt. So essentially you will have two oil pumps now.
    The oil tank that I'm going to have to find a spot for.
    ***Note- I have been waiting patiently for 3+ weeks for this kit. They told me that they are waiting on the oil tank, and it would be no more that a week from when I ordered. Today, they say it may be another 2 weeks (total 5 weeks from when I ordered AND charged my credit card). I asked them to send me the kit minus the tank so I can at least start installing it. They are supposed to call back and let me know. If they cant, I will be cancelling my order and going with someone different.
    Thanks- Chad
  35. #475
    Santa Rosa CA
    how did you apply the plasti dip?
  36. #476
    Clovis, Ca
    Just a normal spray can. I did about 4-5 coats, 10min apart.
    Thanks- Chad
  37. #477
    Tnx
  38. #478
    Gold foil on which pipe?
    Which gold foil, any Chinese knock-off or there are different grades of that?
  39. #479
    Irvine, Ca
    Cool I get that part, I'm just trying to understand how the vacuum is created.
    Is the oil pump responsible for creating that vacuum exclusively? I have read different things on this and trying to get my arms around why some people use the oil pump, some use a vacuum pump while others use the exhaust to get the vacuum to the crank. I have read a dry sump can yield gains of 25HP, which would be a nice added bonus.
    That sucks about Element tuning. I sent them an email stressing my concern so hopefully they step up. I told them my order was contingent on yours being expedited.
    Sorry for diluting your thread with so many drysump questions.
  40. #480
    Clovis, Ca
    That's not my car. That is someone else's. I have not received my kit yet.
    Brandon- No worries. I guess the tank manufacturer is having "employee problems...." Element is sending me a Peterson tank instead. Thanks for the threat, it worked
    I finished putting the belts in the car and mounting the dash. I need to install the ignition panel, and some additional gauges.
    I also received my Aluminum intrusion plate. I need my buddy to notch it with his Plasma Cutter for the coolant tube near my feet, then I can install that.
    Its coming along.
    Thanks- Chad
