Results 1 to 4 of 4
Thread: 3 link to IRS
    Naples, Florida
    3 link to IRS
    Considering Changing from my current 3 link rear to IRS. Have a Mark III roadster FFR5458, curious if this is drop the old and bolt in the new situation?
    Fresno, CA
    The IRS requires welding in the cage to hold the pumpkin, not sure what has to be removed before welding, but it is NOT a bolt in change.
    Doug
    Why are you going to an IRS? You don't have to answer but I'm curious since most people praise the 3 link for all it's benefits. Thanks, WEK.
    Naples, Florida
    I am looking to take the car to the next level of accuracy in replicating an original. Also looking for another project to keep me sane.
