Results 1 to 4 of 4
Thread: brake/clutch master cylinder support
    Nepa
    My chassis doesn't have welded in support for the masters. Do the later chassis have bolt in supports? There's welded tabs but no where in the instructions (they show a welded in support) does it say. Also no mention in the inventory sheets. Am I missing something obvious?
    Santa Rosa CA
    There is a bolt in support, there is an update to the manual and a small bag of hardware labeled pedal support. I think there are 5 or 6 bolts and lock nuts.
    The small bag of Hex head bolts and nuts might also be labeled PEDAL BOX.
    The pedal box support has holes big enough for the clutch and brake masters. If you need a pic of that, I got some and also on my build thread.
    You gotta bolt that support to the frame and those small welded supports.
    Nepa
    I found the bag with the bolts. I called my powdercoater he said there's a bracket in my pile that he believe to be the mount.
    I don't remember seeing it and I panicked. Sorry guys need sleep I guess
