Later,
Mk3.1 #7074
It's always interesting to see how components are installed on a real race car. Function over form is usually the rule. I was curious about the cooling fan. Chris is that an original item from the 60s? When I saw it, I couldn't believe it was that old or from that vintage. Thanks, WEK.
Cars restored for show or street use are usually much more "period correct." Track cars, especially ones that are still working for a living like this one, usually follow rules that allow forward and back dating to comply with certain rules that were in place "back-in-the-day." That means that if cooling fans were unrestricted at some point and the car is built to those rules, then it would be permissible to install a later fan on the car.
Here's the CSX 2323 in Turn 6 at RA during that race... sure seems to be putting miles on it - like four per lap that day.
Later,
Mk3.1 #7074
Wow - those are great pictures.
I must say it looks in great shape but very lean on the creature comforts and fit & finish - I keep forgetting this car still races.
Puts my FFR MK4 Coyote build into perspective - I think I went overboard and I would not have it any other way. With the new UCA's my roadster handles much better and does not seem as stiff - I drive it every chance I get.
Thx for posting.
15th Anniversary Edition
Mk4 - 18 month build (4 hrs every Sat), received Aug 2011, titled & registered May 2013, final in paint Nov 2013 - Ferrari blue
FRPP Crate Coyote 5.0, tko600, Moser 3 link, manual steering & 13" brakes, upgraded coil overs
koolmat then dynamat then carpet in cockpit - very solid, no engine heat transfer to cockpit and no road noise
