Results 1 to 24 of 24
Thread: Cockpit & Trunk Mods : Let's see 'em
    Senior Member jakester888's Avatar
    Portland, OR
    Curious to see what you guys came up with.
    Stereo, cubby & cup holders:
    Cubby hole behind seat & kickbass:
    Switches:
    Hidden compartment in the trunk:
    Trunk separator for speakers, Kicker Amp with hidden battery stored underneath + easy-access charging terminals:
    Chino Valley, Arizona
    Trunk done in Monsterliner (zombie sunset Bedliner) to match Speedhut gauges and tangerine stripes. All panels trimmed in carbon fiber with a rear trim/scuff plate. Tarantula amplifier platform mounted.
    That's bada$$ cgunderman!
    Nice work jakester. BTW: where did you get your cup holders if you don't mind sharing?
    WEK.
    Atlanta, GA
    Here are my mods, I want to do the carpet over. Not happy with the quality of the carpet.
    Let me know what you think.
    Atlanta, GA
    Mods
    Portland, OR
    Quote Originally Posted by skullandbones View Post
    I am not 100% sure but think it may have been Rex Marine.
    http://shopping.rexmar.com/Merchant2...rinkholderssbp
    Portland, OR
    cgundermann : nice!
    ksamson : picture kind of fuzzy... but I do like the kevlar look.
    Senior Member DaleG's Avatar
    Mar 2013
    Thanks - trying for a different look.
    Summerfield, NC
    The front cup holder doesn't look like you could put a cup/can in it...doesn't the shifter interfere with it?
    Looks like it would still be usable for change or a garage clicker though.
    Cobra Driver UpstateCobraGuy's Avatar
    East Greenbush, NY
    IMHO, the ultimate cockpit modification!
    The original "Wyman" Door mod
    Dare ya!
    Pat
    Mark III 4630RD Explorer 302, Holley SA570, FRPP B-cam, 4 to 4's, 3 Link, Bullitt wheels, Baer Brakes, 3.73 gears, HD T-5
    Mark II Rebuilt into 1955 Jaguar D Type Replica Explorer 302, Holley SA670, Trick Flow Stage 1 cam, 3 Link 4.10 gears, Classic Gauges
    PM me if you live in Upstate New York. Get added to the "Upstate Cobras" email list. 60+ members!
    Portland, OR
    Quote Originally Posted by UpstateCobraGuy View Post
    Dare ya!
    Those of us with wider girth can appreciate. Nice job Pat, I didn't notice last time.
    Jul 2014
    jakester - VERY cool mods! I'm curious to know your plan for finishing off the front and rear cubbies? Will you be putting any sort of door or cover over either of them?
    Also, I would really like to install a trunk separator myself - did you find a plan/template somewhere or determine the measurements yourself?
    Finally - for anyone listening - where does everyone get their sheet metal for making these mods??
    Thanks!
    Shannon
    Trunk mod - original style fiberglass trunkpan
    Cockpit mods - original style fiberglass footboxes
    Original style cockpit corners but in glass instead of aluminum
    Bill those mods are off the hook!
    I've made a few mods myself including the cubby, a dash "connector" (hinged lower dash mount). I also converted my Kirket intermediates into "Vintage" buckets.
    Making the wall template. This has to be done custom, IMO to fit YOUR floor and walls. My cubby is 8" deep, and great for jackets and other "stuff" during a long cruise or road trip:
    Here is the trunk cubby wall installed. The whole trunk is fully polished. It's still raw (uncoated) so it takes some upkeep. I polish it up by hand once every year or 2:
    Custom enlarged passenger footbox:
    Hand-made custom dash gauge cluster bezel:
    Here's a bad pic of the Russ Thompson trunk box. I'll try to find another pic showing the trunk floor in place:
    Quote Originally Posted by sph427 View Post
    Thanks!
    Shannon
    I use online metals and metals depot.
    Jul 2014
    Thanks!
    Out Drivin' Gumball's Avatar
    Blackberry Township, IL
    Mine are all of the "old-school" variety...
    Rivets in cowl and door edges (simulating the way the aluminum skin was attached to the original cars):
    Original style grab handle:
    Leather pull strap and support tubes for side curtain ferrules:
    Upper cowl support tube "nub" with notched dash:
    Center support bracket for windshield frame to top of front cowl (underneath the center rod bracket):
    S/C dash layout, but with glovebox and ashtray (neither of which would have been in an original S/C):
    Waxed cord wrapped steering wheel:
    Later,
    Mk3.1 #7074
  19. Likes toadster liked this post
  20. #19
    ... and a couple more:
    AC pedal pads and custom throttle based on original big-block cars:
    Bound carpet edges and leather covering on exposed chassis members:
    Later,
    Mk3.1 #7074
  21. #20
    Switch panel similar to original comp cars
  22. #21
    Portland, OR
    Cool cubby.
  23. #22
    Portland, OR
    Quote Originally Posted by 2FAST4U View Post
    Wow, fiberglass.
  24. #23
    Portland, OR
    Shannon, Breeze sells a cubby separator. Link is here.
  25. #24
    Oct 2014
    Nice colour, what do they call that green?
