Page 21 of 28 FirstFirst ... 111920212223 ... LastLast
Results 801 to 840 of 1089
Thread: Metalmaker's build thread begins
  1. #801
    Exeter R.I
    There is no compromise for an awic set up. I am using Wayne's setup and it should do the trick, and is at a good price and ready to bolt in, time is also money in my world. I will have an iat, egt temp gauge, along with boost oil press and a/f to monitor it and I am running my pistons on the looser end of the specs to allow for heat expantion. I am also going to use an ice box on the hot days.
    All that pipping will get heat soaked and have high pressure drops, it will not come close to be as effective as an awic
    I am running a koyo radiator, but stock should be ok, they just are not super durable.
  2. #802
    Freeport, ME
    How much pipe volume will you have? Do you have any concerns about air volume based boost lag? Also, what core are you using, and just one, or two?
    one on the right side, less than 7 feet of 2.5 inch pipe, you could do it with 2.0 pipe too, might end up with better clearance in places too. See my thread for photos and details. Hopefully I'll have it installed this week... I needed some aluminum welding and I have to ask a friend for that service...
    Dan
  3. #803
    G, metal, you definitely thought of everything humanly possible to cool down that engine. lolll
  4. #804
    Exeter R.I
    Well when you blow ringlands and headgaskets due to really high iats from one hard autocross session after you drove the car fine for 1000 miles on the street, you would do the same playa.
  5. #805
    I give you that. I've always been a freak of cooling down temps, not too much cuz it isn't better! But doing many little or big things to keep them cool. You just prove me right again about that. I'll continue the same way.
  6. #806
    Senior Member BrandonDrums's Avatar
    Triangle area, NC
    Hey Metalmaker, is your shortblock salvageable? If not, I have a used '02 wrx block in good shape for a rebuild for sale. Not a JDM but the shortblock is pretty much the same. I'll let it go for cheap, no one on NASIOC wants a 2.0L anymore.
  7. #807
    Exeter R.I
    Quote Originally Posted by BrandonDrums View Post
    Yeah it's repairable as far as they have measured and tested, I think it's all good, tomorrow I will get full results
  8. #808
    Triangle area, NC
    Fingers crossed for ya man.
  9. #809
    Exeter R.I
    Motors getting some machine love and the bottom will be fully built. The heads will be rebuilt with a haircut but stock trim with a mild port to just clean the ruff casting.
    In the meantime I have ordered plx touch screen gauge for a/f, egt and iat. I also got stri 60mm oil pressure to match my boost gauge. I will be installing them in my dash. I also ordered Wayne's awic, a Blouch 1.5 xtr twinscroll turbo and these injectors. I will be good for 500 plus, but will be tuning it for 300-330whp with a sick powerband and reliability.
  10. #810
    Clovis, Ca
    Nice!
    Thanks- Chad
  11. #811
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    Here's a comparison of air to air intercooler to air to water
    Air to Air with two 10" fans sitting on top of the intercooler
    Air to water low speed fan 3 feet in front of heat exchanger.
    Data log starts at 1.7 seconds at intake air temp of 97 F@2650 RPM
    Data log ends at 8.7 seconds at intake air temp of 106 F@6100RPM
    9°F increase in 7 seconds
    Both engines made 240 RWHP
  12. #812
    Was that an oem TMIC? What was ambient air/water in the tank temp?
  13. #813
    Administrator
    Enterprise Alabama
    That was a stock 07 air to air TMIC on an 07 WRX. The water in the tank had 7 pulls on it and water temp was 96 degrees. Ambient temp was 92-96.
    On the air to air, can you imaging the intake air temps at an autocross with only the air flow from the deck vents vs the 20°F/6 seconds with two 10" fans sitting on top of them?
  14. #814
    Freeport, ME
    Stock location can't work... no air flow
    Dan
  15. #815
    Encinitas, CA
    To me, the data clearly show that, compared to a AWIC, the stock A2A IC performance is compromised even with adequate airflow; this would be the case in the original fitment (WRX); in a stock 818 the temp rise would be greater.
    What would be interesting is to know where the delta-T levels off at a typical power duty cycle representative of track duty, with adequate airflow. This would answer if the stock IC could be ever be useful even with proper ducting.
    Hmmm... My 818 will be primarily a street car, but I'm starting to think about the AWIC!
  16. #816
    Administrator
    Enterprise Alabama
    Time (s) RPM MAP (kPa) TPS (%) MAT (°C) WT (°C) AuxT (°C)
    1.857 2658 115.8 69.5 - 80 36
    1.95 2780 117.6 97.6 - 80 36
    2.013 2792 113 97.6 - 80 36
    2.059 2799 114.4 97.7 - 80 36
    2.137 2848 118.3 97.6 - 80 36
    2.2 2856 114.5 97.6 - 80 37
    2.293 2911 115.5 97.6 - 80 37
    2.356 2931 118 97.6 - 80 37
    2.371 2931 118 97.6 - 80 37
    2.449 2963 114.4 97.6 - 80 37
    2.512 2998 117.8 97.7 - 80 37
    2.574 3025 115.5 97.7 - 80 37
    2.668 3040 114.8 97.6 - 80 37
    2.683 3040 114.8 97.6 - 80 37
    2.746 3088 115.5 97.6 - 80 37
    2.839 3131 115.9 97.6 - 80 37
    2.871 3151 120.6 97.7 - 80 37
    2.933 3158 117.1 97.7 - 80 37
    2.995 3188 116 97.7 - 80 37
    3.073 3227 116.1 97.7 - 80 37
    3.136 3277 118 97.6 - 80 37
    3.198 3297 119.4 97.6 - 80 37
    3.276 3344 117.8 97.6 - 80 37
    3.292 3354 118.1 97.6 - 80 37
    3.385 3413 117.8 97.6 - 80 37
    3.448 3419 119.9 97.7 - 80 37
    3.526 3480 118.6 97.7 - 80 37
    3.588 3482 117.8 97.6 - 80 37
    3.635 3524 118 97.6 - 80 37
    3.697 3562 120.5 97.7 - 80 37
    3.76 3582 117.3 97.7 - 80 37
    3.838 3638 120.3 97.7 - 80 37
    3.869 3657 120.8 97.7 - 80 37
    3.931 3688 116.4 97.6 - 80 37
    3.978 3688 116.4 97.6 - 80 37
    4.056 3752 115.5 97.7 - 80 37
    4.119 3785 117 98.2 - 80 37
    4.197 3829 121.3 97.7 - 80 37
    4.259 3873 119.3 97.7 - 80 37
    4.321 3900 120.4 97.7 - 80 37
    4.399 3944 118.3 97.7 - 80 37
  17. #817
    Administrator
    Enterprise Alabama
    4.431 3975 119.3 97.7 - 80 37
    4.509 3995 122.8 97.7 - 80 37
    4.571 4038 121.4 97.8 - 80 37
    4.633 4067 118.1 97.7 - 80 37
    4.68 4076 118.9 97.6 - 80 37
    4.743 4129 119 97.7 - 80 37
    4.992 4264 123.1 97.7 - 80 38
    5.023 4264 123.1 97.7 - 80 38
    5.039 4264 123.1 97.7 - 80 38
    5.133 4333 122 97.8 - 80 38
    5.179 4350 123.5 97.7 - 80 38
    5.242 4374 120.7 97.7 - 80 38
    5.304 4401 123.3 97.6 - 80 38
    5.398 4464 122.8 97.7 - 80 38
    5.445 4478 124.3 97.7 - 80 38
    5.507 4503 120.5 97.8 - 80 38
    5.601 4543 122.7 97.7 - 80 38
    5.71 4603 123.8 97.7 - 80 38
    5.757 4633 124.8 97.8 - 80 38
    5.819 4652 124.6 97.7 - 80 38
    5.881 4699 121.4 97.7 - 80 38
    5.944 4726 122.5 97.6 - 80 38
    6.022 4762 123 97.8 - 80 38
    6.069 4791 125.3 97.7 - 80 38
    6.162 4836 126.5 97.7 - 80 38
    6.178 4836 126.5 97.7 - 80 38
    6.256 4878 123.7 97.7 - 80 38
    6.303 4908 123.6 97.7 - 80 39
    6.365 4955 126.8 97.6 - 80 39
    6.427 4977 126 97.8 - 80 39
    6.505 5022 122.6 97.7 - 80 39
    6.583 5081 126.8 97.7 - 80 39
    6.646 5090 126.1 97.7 - 80 39
    6.693 5118 126.6 97.7 - 80 39
    6.739 5146 124.6 97.7 - 80 39
    6.849 5193 125.7 97.7 - 80 39
    6.927 5261 127.8 97.7 - 80 39
    6.973 5286 126.5 97.7 - 80 39
    7.02 5311 128.3 97.7 - 80 39
    0
  18. #818
    Administrator
    Enterprise Alabama
    7.083 5331 127.6 97.7 - 80 39
    7.098 5357 127.8 97.7 - 80 39
    7.192 5419 127.7 97.7 - 80 39
    7.301 5429 127.4 97.8 - 80 39
    7.317 5429 127.4 97.8 - 80 39
    7.379 5503 127.1 97.6 - 80 40
    7.426 5520 127.8 97.7 - 80 40
    7.488 5547 127.8 97.7 - 80 40
    7.535 5597 128.8 97.7 - 80 40
    7.629 5647 129 97.7 - 80 40
    7.691 5664 129.4 97.7 - 80 40
    7.753 5710 129.1 97.6 - 80 40
    7.847 5757 128.7 97.7 - 80 40
    7.878 5757 128.7 97.7 - 80 40
    7.941 5810 128.5 97.7 - 80 40
    8.019 5853 128.2 97.7 - 80 40
    8.081 5877 128.3 97.6 - 80 40
    8.128 5908 130.7 97.8 - 80 40
    8.175 5921 131.8 97.7 - 80 40
    8.268 5939 129.6 97.7 - 80 40
    8.331 6035 130.6 97.7 - 80 41
    8.424 6035 130.6 97.7 - 80 41
    8.471 6035 130.6 97.7 - 80 41
    8.533 6035 130.6 97.7 - 80 41
    8.596 6035 130.6 97.7 - 80 41
    8.658 6035 130.6 97.7 - 80 41
    8.721 6035 130.6 97.7 - 80 41
    8.783 6035 130.6 97.7 - 80 41
  19. #819
    thanks for the data!
  20. #820
    Freeport, ME
    The stock IC can't allow air to flow through very well so much of it is covered by that stupid Y pipe, disrupting smooth flow
    Dan
  21. #821
    Exeter R.I
    Oh I can imagine and so can my engine.
  22. #822
    Exeter R.I
    I am going to start a depowering the rack gig. I have done about 10-15 other car types and 5 818 conversions and now I figure I will offer the service.
    The drop off fee: $200
    Mailing in fee of: $240 ( you pay to mail it in, but I do work and mail it back to you, and mailing fee is included in price)
    Includes: teardown and seal removal, cleaning, pinion and line end welding, blasting, painting of line ends re-assembly with
    High temp greese, and new boot ties.
    Any other parts that are needed ( bushings, boots, inner parts etc, will be added to the bill with no additional labor
    PayPal or cash only
    Pm if your interested.
  23. #823
    Senior Member Aloha818's Avatar
    Waikiki
    Sorry you had the engine failure, but looks like it was a good excuse to really up the game!
    "In wine there is wisdom, in beer there is strength, in water there is bacteria."
    818 (Chassis #34) Delivered 9/25/2013, First start 3/2/2014, First drive 4/5/2014, Registered 8/28/2015, First Dyno 3/18/2016, First SCCA event 4/3/2016, First car show HIN Honolulu 4/23/2016
  24. #824
    Exeter R.I
    Yeah, the awic is a great way to save yours and others, the IC will just not get the air it needs to function correctly.
  25. #825
    Triangle area, NC
    I've been considering doing an AWIC setup on my WRX now just having read through a lot of threads on the AWIC. However, in my reading it sounds like the down-side of the AWIC is still a higher propensity to heat-soak on long track stints. AWIC is mostly used for short drag-racing runs and drift stuff where heat-soak isn't an issue because it's just a couple laps.
    http://www.enginebasics.com/Advanced...tercooler.html
    I know it's going to be better than a stock TMIC setup to run AWIC in an 818 but what if you could get more reverse flow through the IC by mounting a large FMIC against the mesh outlet of the 818R rear-end? The massive low-pressure cavity behind the trailing end of the car pulls air in through the sides, top and bottom of the engine bay and sucks it out through there.
  26. #826
    Administrator
    Enterprise Alabama
    Well just having finished a weekend at Barber with a SC Elise with an AWIC I can attest that the heat soak is not an issue. After a 20 minute race, the water in the coolant tank was 114°F on a 94° day. That was the equilibrium point with the size of heat exchanger installed. As you can imaging it's less than 50% of the size of the heat exchanger that is in the 818 AWIC I sell due to how small the nose is in the Elise.
    Brandon, putting the A2AIC there will feed the intercooler engine heated air and not ambient.
  27. #827
    Speaking of AWIC, metalbreaker where are you running your coolant lines from the tank to cooler? Along side the engine coolant tubes in the door sills?
    Another question, normally what is better to increase efficiency of an AWIC setup? A larger heat exchanger, a bigger cooler or a bigger tank with more water?
  28. #828
    Administrator
    Enterprise Alabama
    Bigger HE and tank will increase the time to heat equilibrium.
  29. #829
    Research Calibrator sponaugle's Avatar
    Portland, OR
    A temp switch? Temp sensor with a gauge would be a good way to monitor it, along with an indicator light on the pumps ground side so it turns on when pump is on ( unless you run it full duty). With speed density we could tune the wrx to use a iat temp sensor after the turbo. I am working on that aspect also. Wayne's got his wiring setup also, but it can be done with the factory ecu.
    If you wire a fast response IAT sensor into the stock ECU you can use the ECU tables to do an effective engine cut if IATs get too high. Most of the Subaru ECUs have wastegate and boost target trim based on IAT, as well as ignition timing. I have my 08 STI maps set such that IATs above 140 degrees results in no additional boost above wastegate and a retarding in timing. The drop in boost is very noticeable and you would immediately know something is wrong.
    Not to smash your insightful suggestion, but I have heard, witnessed this can cause issues because the iat is integral to the maf and the Ecu in a maf based configuration relies on it to be where it is stock.Also the response time of Ecu based iats is pretty slow, so with improper resistance to that circuit it could cause insufficient readings and actually not do any good. I am trying to intergrate a whole new circuit to work with that circuits signal wire but be seperate. I am the idea guy, some of my electrical guru friends are working on it. They have had issues on customers cars with the splicing. If you run a setup like Wayne's were it is intergrated into his system to run the iat anywhere like SD than that is the way to go, but with a maf it's a bit more tricky cause you must compromise the circuit to achieve two iats.
    In fact I am pretty sure it would not even function. The iat is a resistive sensor. No way you can tie two together because if this. When you change the iat you have to change the scalar in the Ecu. You def can't put two in parallel.
    I would really encourage running SD in a case like this. With SD you have very fine control of fueling and load mapping, plus a good fast IAT. I use an IAT sensor in the boost tube for my 08, wired into the MAF IAT circuit.
    Nice. I'm also going to use the VCP AWIC setup.
    I'm curious as to your piston tolerances. Here is how I built my motor last week ( new case, ACL bearings, Weisco pistons. ) Any idea how they compare?
    Cheers, Jeff
  30. #830
    Triangle area, NC
    Quote Originally Posted by sponaugle View Post
    Cheers, Jeff
    Yeah, those clearances look about right. Personally, I prefer the rod bearings to be a bit looser than stock. Mine are all .00185"-.002'' and I ended up allowing the machine shop to resize a couple rods to get there after going through two sets of ACL "Race" Bearings. After two rod bearing failures I figured it's more important to get more oil flow there for heat evacuation purposes. Seems to be working out well.
    Also, it needs to be said that the only way to get a post-turbo/IC IAT dependent tune on a stock Subaru ECU is to convert to speed density. I don't know if that was clear in your post. If you're on a MAF tune, it's not really possible to put another IAT sensor elsewhere on the intake tract. Replacing the MAF with an upgraded one still means having IAT reading come before the turbo. However, if you have more info on how to add another IAT on a MAF tune, link me to some readin' cause' I'll be doing that asap.
    Yeah, but that's practically the case with the TMIC where it is. At least by moving it back to the tail end you'll have more air flowing through it and get the TMIC away from the hot turbo and away from being directly over the engine. Not ideal but a likely improvement over the stock location. Could perhaps be an option for re-locating the stock TMIC for a temporary solution for budget guys. I'd love to get some airspeed and temp readings from there vs. the stock location.
  31. #831
    Exeter R.I
    I am running my plx device Afr, ait and egt modules with a dm-6 multi touch gauge. I will monitor the awic's efficiency.
    As far as I know and other local tuners you can't just add an iat sensor to the maf ( in a maf setup) and expect the ecu work properly on all it's tables.
  32. #832
    USA
    You don't see it very much anymore because SD is so prevalent, but a blow-thru MAF setup allows you to get more accurate IAT readings post intercooler.
    http://perrinperformance.com/i-13324...7-wrx-sti.html
  33. #833
    Portland, OR
    Bingo. There is no reason you can't put the IAT sensor after the intercooler, even if you have the MAF before the intercooler/turbo. Back in the day (as the saying goes), I did both, and both worked well. The blow thru MAF setup is a bit funky, but it can be made to work. In both cases you have to make some adjustments to the Intake Air comp tables. If you have the IAT after the turbo it will see much higher IAT and as such you will want to change how the compensations are applied. Give me a sec and I'll post up a sample set of tables.
    I have used the PLX devices extensively, and actually I used to be a dealer back in the PDX days. I'll post up some more comments in my build thread so as to not pollute yours. There are some interesting pluses and minuses.
    Indeed I have done the aftermarket IAT sensor with the factory MAF sensor plugged in. The factory MAF will still have an IAT sensor in it, but I cut the wire to the ECU and added my own IAT sensor post turbo. While I would prefer to be on a speed density tune for this, you can do it MAF only. The MAF sensor itself it temperature dependent and temperature correcting, and the IAT sensor inside the MAF sensor can simply be disconnected from the ECU while leaving the MAF signal connected.
    If you were going to this trouble you might consider just doing a blow-thru MAF, or as you suggested just switch to SD.
    Portland, OR
    Here are the tables I was talking about.. these are for an 06 WRX ECU:
    The first table is the calibration table, which you have to change if you use a different sensor. Pretty easy.
    The second table is timing compensation, which you would need to make flatter up to 210, then roll down. This is very useful for an AWIC because if post AWIC you AITs are over 220-230 you have a problem.
    The third table allows you to get rid of WGDC at high IATS.
    The forth is one of three tables that adjusts the PID algorythm based on IATs.
    There are a few other tables, but they are of similar construction. If you move the IAT sensor to a post turbo/IC spot, you just need to adjust these accordingly.
    what a great idea.
  36. #836
    Exeter R.I
    Seems simply from the way your explaining it, but I bet its harder to get just right so it all runs smoothly. I will work on it on the dyno, hopefully I can get it to work correctly
  37. #837
    true but, before converting you can do plenty of datalogging of the actual IAT and see what your delta between the mafs readings are over various conditions. from there table two shouldn't be too hard to tweak. looking at Jeff's values IAT over 176 is unlikely, so you are really only generating 4 or 5 values. not too bad. start conservative and then add a little timing.
  38. #838
    Exeter R.I
    Got HE mocked up, had to play around with it because my lower aluminum gets in the way of Wayne's design slightly. I still have to re align the brass fittings to work the way I want, so nothing's final except the location of core. image.jpgimage.jpg
  39. #839
    That's a nice HE, what are its size specs? I am looking for exactly that type. EDIT: Sorry metalbruins, I just realized it's on Wayne's AWIC thread so I have asked there.
    http://thefactoryfiveforum.com/showt...l=1#post168412
    Other thing, where will you install your tank?
  40. #840
    Exeter R.I
    What tank do mean??
    Metalbruins "A", which team is yours, Montreal, leafs etc
